Stelvio: Problem with the radial wheels
#1
Posted 23 November 2009 - 04:09 PM
Had anyone any problems relating to air loss from the wheels of the Stelvio? A friend of mine complains that almost every 2 days he has to add air in the wheels. The problem is spotted in both front and rear wheels.
He has already checked the tyres. No holes. Nothing.
Thank you
Dimitris
#2
Posted 23 November 2009 - 07:36 PM
Dear Stlevio owners,
Thank you
Dimitris
Hi Dimitris! [What's a good greeting in Greek?]
Two things for keeping air in motorcycle tires:
1) All Schrader style valves leak. The faster you go, the faster they leak [assuming the normal "vertical" style valve stem] due to centrifugal forces depressing the valve. Get metal valve caps with the o-ring or rubber gasket inside them to seal the valve stem, preferably hex shaped caps so you can tighten them with a wrench rather than pliers. Even finger tight is good w/ the hex style, since you can get better purchase than with round ones...
2) Almost all motorcycles & cars come with rubber valve stems. They're crap, but they're cheap & easily installed, so that's why the manufacturers use them. The 1st time you change tires, swap out the rubber valve stems for metal ones. They'll typically last the life of the vehicle, and won't develop leaks at the interface with the rim. Since you'll be spending a few $$ [or drachmas, rubles, euros, whatever] for them, you might as well spring for angled metal valve stems & resolve the access issues at the same time, so future air pressure adjustments are simplified.
#3
Posted 23 November 2009 - 08:26 PM
#4
Guest_Cantaloop_*
Posted 29 December 2010 - 06:15 PM
#5
Posted 17 January 2011 - 08:06 AM
Yes, I think that was the cause. I don't know what happened since then.Unfortunately, there are cases in which the sealing of the spokes does not work so well.
#6
Posted 17 January 2011 - 10:04 AM
Take wheels off, dunk in a bath full of water and watch the spokes. The one/s with bubbles coming out are the ones with f@cked o-rings.
Pete
#7
Posted 17 January 2011 - 09:48 PM
First lines from that:
1) We do not recommend cleaning the wheel with high pressure cleaning systems, whether hot
or cold water is used.
If you do intend to use a high pressure cleaning system, keep the jet nozzle
at least 50 cm from the area in which the nipple passes through the rim (see Pos. 30 in Fig.
20).
Bringing the jet too close to the nipple may force dirt between the nipple itself and the rim,
compromising the air tightness of the assembly and damaging the seal.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
