IPB Style© Fisana
Looking at a 96 sport 1100 - some questions
  • Please log in to reply
10 replies to this topic
#1 Paul in NM
Paul in NM
    Rookie
  • 10 posts
  • My bike(s):
    Soon to be Le Mans
    Albuquerque, New Mexico
Posted 12 April 2011 - 10:03 PM
Ok so I'm looking at a 96 Sport 1100. Had a few question (more to come of course should I buy it :rolleyes: ). Bike has 14K and a bunch of recent work including trans overhaul with closer gears by Hecht and a hotter cam (trying to find out which one was installed. I was told idle is a tad higher due to new cam). Carbs seem to be stock Dellorto 40's. Deep sump and external oil filter added. Frame was powder coated. Rear end was resealed and vented. New WP rear coil. New front disks.
Several things I'm not so familiar with...
- They added a quick throttle kit and had to reposition the starter button a tad higher to the right
- They have a 2 battery system - new 9v's side by side (I do recall reading about this one before)
- Current clip on's are too low interfering with the tank (need to go back to stock - available?)
Any info appreciated.
Posted Image
#2 2or4strokes
2or4strokes
    Guzzisti
  • 70 posts
  • My bike(s):
    guzzi copa italia, sports 1100i,
Posted 13 April 2011 - 12:18 AM
Posted Image
Hi Paul
The reposition of the starter button is probably a clearance issue with the quick throttle so I don't think it's an issue.
The original battery is position below the rear seat and it's not a 2 battery system but a single one . I'm running one with a 12 v/14amp rating battery. Since this area isquite big finding a suitable battery should not be a problem. Why is it 9v I don't understand.
The bike originally comes with white power front and rear <(at least the sports 1100i did)
It also comes with a steering damper originally.
What can I say is that I love the sports 1100i looks and riding experience.
#3 Skeeve
Skeeve
    "I live here"
  • 2,428 posts
  • Location:Lo-cal So.Cal., where the money is plastic & the people are too!
  • My bike(s):
    2003 Le Mans V11. WooHoo! :-D
    SW corner USA
Posted 13 April 2011 - 05:53 PM
Did you mean two 12v 9ah batteries in parallel? That would make sense, but 2x9v=18v which would blow any of the electronics on the bike which were designed for a nominal 12v... :unsure:
I seem to recall that the Spot originally came w/ 2 batteries, one low & forward & the other under the passenger seat, & that once AGM batteries came out it was normal to just use the low&forward position w/ 1 battery doing all the chores, but maybe I have that confused w/ a different bike?
#4 Paul in NM
Paul in NM
    Rookie
  • 10 posts
  • My bike(s):
    Soon to be Le Mans
Posted 13 April 2011 - 06:32 PM
I'm thinking that's what he meant.
#5 GuzziMoto
GuzziMoto
    Forum Flooder :)
  • 1,146 posts
  • My bike(s):
    '07 Griso '01 V11 Sport '93 Daytona 4v '07 Suzuki DRZ400Supermoto(Sold) Aprilia RXV550 Roadracer project
    South B'more
Posted 15 April 2011 - 01:11 AM
I believe Ducati has done that trick (two batteries). Not sure about Guzzi, but I know my '93 Daytona only has the one battery under the seat.
#6 dark_bike
dark_bike
    Guzzisti
  • 96 posts
  • My bike(s):
    2002 Scura
    Cologne, Germany
Posted 28 April 2011 - 12:07 PM
I have a '95 one with carbs and that has two batteries under the passenger seat. The set-up doesnt look improvised so I guess it's standard. (dont have a WSM at the ready now to check)
The original clip-ons are set very low too, real chin-on-the-tank stuff...are you sure yours are NOT standard?
Tom
#7 pete roper
pete roper
    "I live here"
  • 1,933 posts
  • My bike(s):
    Lots of old shite. And a Griso!
Posted 28 April 2011 - 12:29 PM
Sport C gearboxes are remarkably fragile if they are treated 'Gently'. Most likely the bike's PO, (Or one of them.) was a posing softcock. I recently responded to another query about a newly 'Found' Sport C on another board so to save me repeating myself I hope you won't mind if I C&P even if it seems a bit odd?
Right. A few pointers on the Carb Sports.
First thing. Drain the gearbox oil. if there is anything but the very lightest 'fuzz' on the magnetic plug your first task is to pull the box and take it to bits. Sorry, but if you do it now it will save pain later on. The Carb Sports use a straight cut gearbox with only three dog engagement. they also don't have a cush drive in the rear wheel and their face cam shock absorber on the input shaft has a 'stacked belville washer' spring that is VERY unforgiving. If the bike has spent ANY time being ridden by a softcock there is a good chance that the pinions will be beginning to hammer the case hardening off some of the teeth. 5th goes first, which is lucky because it's the only gear you can replace individually. Then 3rd because this works twice as hard on the clustershaft as its where the power comes in as well as driving out to the output shaft in 3rd. IMHO It's worth going into the box anyway as the 3205ATN9 beaings on the front of the input shaft and rear of the output shaft are shite. Replace with 3205 AC3's which instead of 9 balls per race and a plastic, polyanamide, cage have 14 balls per race and a sepentine metal cage! Both are rated to over 10,000 RPM. If you're spinning your crank at over 10,000 RPM your oil pump will be cavitating and your big ends will last seconds, before that happens it'll probably chuck out a rod! You'll NEVER overtax the 3205AC3's While you're in there you can shim up the selector drum for a better change too. I'd recommend puting in a helically cut 5th with 5 dog engagement from a later Cali instead of the straight cut 3 dog 5th. You won't notice the difference and if you're riding hard in the twisties you'll never use 5th anyway!
Gearbox strip and shim instructions, with pics, are available at Greg Bender's wonderfull 'This Old Tractor' site in the archived Guzzitech dk section.
http://www.thisoldtr...m/guzzitech.dk/
Make ABSOLUTELY SURE that the drive shaft trunnions are aligned correctly. The crosses have to work in the same plane. If they are misalligned you will bust splines and destroy gears.
Carburetion. Your bike is stock. Stock they run a pressurised airbox. While this is completely pointless from a power point of view until you are going well in excess of 100mph it IS important to remember if you choose to fit pod filters and dump the airbox. To work correctly the carb float bowls are vented to the AIRBOX, fuel is PUSHED into the venturi by pressure acting on the surface of the fuel in the float bowl. To work correctly the pressure has to be equal to that in the airbox, not atmospheric. If you simply remove the airbox you HAVE to re-jet/needle/atomiser and slide or it'll run like a three legged hippo with a spear up its chuff. Keeping the airbox will allow you to get the jetting right without too much faffing about. You won't gain a lot with pods anyway so I wouldn't bother. Also the brown, anodized DellOrto carb bodies have a peculiar habit of suddenly, and for no discernable reason, *Swelling*! This isn't visible obviously but what happens is that the pillars that the float pin goes through seem to 'Grow' and this leads to the float being 'Grabbed' so it can't pivot. As a result the needle and seat leak and the float bowls over-fill causing the bike to slowly become too rich at idle and eventually die! The fix is stupidly easy. Remove the float pivot, float and needle and make a couple of qick swipes across the inside of the 'Pillars' with a smooth file to remove a thou or two of material. End of problem. Floats will now move freely so the needle closes the seat and it won't over-fuel at idle. Make sure that there is at least 2mm of free play in the 'Choke' cables.
Clutch cable also must have at least 2mm of play at the arm at the back of the gearbox. Otherwise you ride the thrust bearing and it'll fail.
Most important of all. Ride it like you stole it! NOTHING damages a Carb Sport more than treating it like spun glass. The NEED to be flogged hard and put away wet! That's just the nature of the beast!!!!
pete
PS. My guess is that the gearbox work was done to correct failed case hardening or bearings. Chances are it now has a helically cut box in. this can be seen by taking out the filler plug and having a squizz at the gears.
#8 dark_bike
dark_bike
    Guzzisti
  • 96 posts
  • My bike(s):
    2002 Scura
    Cologne, Germany
Posted 15 August 2011 - 07:07 PM
When I bought my bike it had pods fitted, but I refitted the airbox to get it past the test for importation. Now that it is finally registered I've been driving it and though it runs nicely it hasnt much ooomph..I barely make it to 150 kp/h (90 mph). Could that also be a rejetting issue? it simply feels like the engine is not getting enough fuel. If the jets would have been altered to suit the pods I'd think the reverse would be true. any ideas?
Tom
#9 aermacchi250
aermacchi250
    Guzzisti
  • 26 posts
  • My bike(s):
    1996 sport 1100,1986 lemans 1000,2004 Lemans v11
    hudson,ny
Posted 13 January 2012 - 12:39 AM
Posted Image
Hi Paul
#10 aermacchi250
aermacchi250
    Guzzisti
  • 26 posts
  • My bike(s):
    hudson,ny
Posted 13 January 2012 - 12:53 AM
The 96 sport 1100 Does Not have One Battery Below the seat.It has 2 Batteries Below the "Rear" seat .Two 12 volts,one behind the other.They're Sealed and on their sides. I happen to have a 96 Sport 1100
#11 rocker59
rocker59
    Forum-aholic
  • 721 posts
  • My bike(s):
    '91 LeMans 1000, '96 Sport 1100, '00 Bassa, '04 LeMans Nero Corsa
    The Trans-Mississippi
Posted 19 January 2012 - 01:35 AM
Damn! Lots of wrong info about Carb Sports in this thread! I'm surprised, quite honestly!
The Carb Sports came with two Yuasa batteries under the passenger pillion.
The Carb Sports came with a conventional Marzocchi M1 front fork. WP rear monoshock with reservoir mounted on the left side of the seat subframe.
The Carb Sports were originally equipped with Bitubo steering damper.
The stock clipons were mounted below the triple tree. Those look like stockers, from what I can see, and simply need to be slid up to the bottom of the triple tree.
I don't know what hotter cam there is than the Crane cam that cam originally in the Carb Sport. There may be one, but I haven't heard of it.
The Carb Sports all had black frames, so this machine has been completely apart to get its red paint/powder.
Pete is good to warn of the transmission. There is no cush drive in the driveline, so be gentle. Some bike's 5th gears shit the bed due to improper manufacturing.
They are great, and elemental sporty motorcycles. I have owned my Sport 1100 since new. Fifteen years, now...
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
