IPB Style© Fisana
Converting Speedometer to Electric Drive
  • Please log in to reply
23 replies to this topic
#16 profWacko
profWacko
    Guzzisti
  • 126 posts
  • My bike(s):
    2000 Jackal, 1976 Convert, I miss my former LeMans's
    Austin, Tx
Posted 09 August 2012 - 01:22 AM
Craig,
Those guages look nice in there.
With regards to the hall effect sensor, I found this one which looks to be lower profile.
Posted Image
What type of adapter did you need to fit the oddball GM female threads onto the Guzzi male side?
-Brian
Please tell us where you sourced this spiffy little item.
Could be a game changer.
ADVthanksANCE
-Jack
#17 felix42o
felix42o
    Forum-aholic
  • 543 posts
  • My bike(s):
    2002 Lemans Tenni, FBF CF pipes, Stucci x-over, K&N pods, PCIII USB.
    Coronado, CA
Posted 09 August 2012 - 11:11 PM
Craig,
Posted Image
-Brian
ADVthanksANCE
-Jack
I looked around on ebay and came across it. I believe that one is an Autometer unit. The Stewart Warner 82527 looks to be an even lower profile, but I dunno how tall it would be after an adapter was set up to mate to the trans.
#18 Craig
Craig
    Guzzisti
  • 66 posts
  • My bike(s):
    2004 Ballabio
    Tucson, AZ
Posted 13 August 2012 - 07:32 PM
Craig,
Posted Image
-Brian
I machined an adapter to go from the metric male thread to the SAE female thread. It helps to have a lathe.
What is the internal thread on that part? If it is the GM thread used by the sender I have, it would be a very nice fit.
#19 felix42o
felix42o
    Forum-aholic
  • 543 posts
  • My bike(s):
    Coronado, CA
Posted 16 August 2012 - 03:51 PM
It should be the same GM 7/8-18 on all of them. I'll see if they have one at the parts store near here and take a look. It would be cool to use that setup, but then we'd need a supplier for adapters... :whistle:
#20 Craig
Craig
    Guzzisti
  • 66 posts
  • My bike(s):
    2004 Ballabio
    Tucson, AZ
Posted 20 August 2012 - 05:15 AM
I have had a few people ask. I could probably do a small run, but, frankly, my machining skills are good enough for me, but not production...
#21 felix42o
felix42o
    Forum-aholic
  • 543 posts
  • My bike(s):
    Coronado, CA
Posted 20 August 2012 - 06:32 PM
So are Moto Guzzi's, in many ways... :lol:
#22 Craig
Craig
    Guzzisti
  • 66 posts
  • My bike(s):
    2004 Ballabio
    Tucson, AZ
Posted 13 October 2012 - 04:55 AM
I was asked what gauges I used. The Tach and Speedo are VDO Viewline Gauges. The Tach say it is for 4-6-8 cyl, but can be convinced to work with 2 cylinders.
#23 Kiwi_Roy
Kiwi_Roy
    Forum Flooder :)
  • 867 posts
  • My bike(s):
    2001 VII Sport, 84 California II, 72 Eldorado
    New Westminster BC
Posted 23 April 2013 - 04:59 AM
I chose a couple of gauges from Speedhut, they let you configure them to your own liking, If I were to do it again I would get the eagle logo added
I made a sensor from a magnet and reed switch
http://s1304.photobu...show/Guzzi Dash
I encourage you to try building a gauge, here's a starting point
http://www.speedhut....1|37:3|38:1|1:4
http://www.speedhut....y/1:2|37:3|39:1
Note; They make GPS and Canbus speedos as well as pulse input ones, be careful not to choose Canbus
#24 Keith Foster
Keith Foster
    Guzzisti
  • 251 posts
  • My bike(s):
    2004 Nero Corsa
    Eastern Shore of Maryland, USA
Posted 12 May 2013 - 04:21 AM
My ITI odometer gears stripped out and I can't find any way of repairing it. I would like to keep the bike somewhat saleable, which means replacing with a bike speedo won't cut it. The plan is to use VDO 80mm Speedo and Tach. The instruments should fit in the gauge cluster without too much persuasion. The trick will be to interface a hall effect drive to the bike. The first attempt will be a GM Hall effect drive available from many places. In this case eBay $20 shipped.
The first problem is to adapt the threads. The GM sender is a female 7/8-18" thread, which is very unusual. Luckily I have a lathe and a modicum of machining skill, so I will machine an adapter. The bigger problem will be fitting the sender and associated wiring beneath the throttle linkage. There is very little room as this picture shows:
When the throttle is wide open the fitting only clears the top of the sender by 1mm or so. Once I have the adapter machined I will cut down the skirt around the connector pins and solder leads directly. This will allow me to increase the clearance by 10mm which should be plenty. I will put a weather pack connector closer to the meter to allow for disconnection later.
This has been done on a different model of Guzzi, and was documented here. Luckily for him his speedo drive was further aft and only interfered with non-moving parts.
I think somebody here got around this problem by having a short drive cable made so that the sender could be positioned out of harms way,but your way could be better.
That would be me :2c:  ...my conversion is documented here...
http://www.v11lemans...&hl=speedometer
Nice work here too!
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
