Ever since I got my Metallic Olive '97 1100i Sport, I have thoroughly enjoyed the ride and the lines of the bike, but I felt it was lacking in quality parts at the cabin. The clunky plastic mirrors really annoyed me as well. At first, I put on my leftover stock mirrors from my Rosso Corsa after installing some mock Carbon Fiber looking ones to that. They worked much better, but still look out of place, and too chunky on the low slung fairing. I have since ordered mirrors from this seller on Ebay:
MCMotorparts
They look to be aluminium and have a nice "weave" effect to them. I have not received them yet, but I will update with pics as soon as I install them.
Anyway, on to what I have done... I have always wanted to deck out the bike with Rizoma parts, especially the grips and turn signals. I had contacted Rizoma USA to see whether or not they knew if their Grips and Throttle Tubes would work with the 1100i. Of course, they had no idea - and nobody carries this stuff in stock. So ifigured, it worth a try, and that I would be able to make everything work. So I ordered the Sport Line Grips and the Avio 21 Signal Lights.
Qualitywise - you get what you are paying for. The units are all really beautiful. The signal lights come 1 per pack, and each has 2 resistor packs should you need them. The Rizoma units mount via M8 bolts and have a nice rubber base to keep vibration to a minimum. A washer and nut tighten everything down - just make sure you thread the wires through the washer and nut first! On this install, I only needed 1 resistor in-line for each the left and right circuits. I installed them at the rear, as there is more room to put them. I did however replace my stock mehanical flasher unit with an electronic one. At the front, I used a circular file to slightly widen the front opening where the wires from the factory T/S's fed the wires through the fairing plastic. At the plastic rear Hugger, the opening is large enough and flexible enough to simply thread the M8 bolt right in.
Here is the result:
Here you can see how bright! Much better and cleaner than stock – at least IMHO…
The Sport Line Grips were also an easy install. Use the largest throttle CAM and the spacer that comes in the package – there are 3 different size CAMS plus a spacer. I also bought the Rizoma end caps and installed them. I might need to go with heavier weights, or I might stuff the clip-ons with shot to keep bar vibration to a minimum.
I very much like the look.
You can also see the matching Pro-Tek Reservoir Cover for the Brake.
I will update this when I get the new mirrors on.
Gersh
