IPB Style© Fisana
Sport 1100i - Headlamp alignment problem.
  • Please log in to reply
14 replies to this topic
#1 John Neeson
John Neeson
    Guzzisti
  • 20 posts
  • My bike(s):
    sport 1100 injection 1997
Posted 12 August 2012 - 10:20 PM
Hi Everyone,
My 1997 Sport Injection is due its annual MOT test. Every year I get the same comment from the tester (sometimes followed by a fail certificate): The headlamp beam is too high! In spite of the fact that it is set to point as low as is possible. In fact the bottom edge of the headlamp is hard against the fairing!
The only change that I have made since buying the bike, is to drop the yokes so that the fork sliders are 10mm above the yokes - which according to my workshop manual is how they should be. This should have improved the headlamp aim. Also running a 160/60 rear tyre instead of the recommended 160/70.
The headlamp bulb is marked:"Osram Bilux 64193 Germany 12V 60/55W". I cannot figure out what the problem is. Has anyone out there had a similar problem with this bike?
#2 Skeeve
Skeeve
    "I live here"
  • 2,428 posts
  • Location:Lo-cal So.Cal., where the money is plastic & the people are too!
  • My bike(s):
    2003 Le Mans V11. WooHoo! :-D
    SW corner USA
Posted 13 August 2012 - 12:07 AM
Well, that lower profile rear tire is going to lower the back of the bike ever so slightly, which would raise the beam a tad. Can't think it would be enough to get you to fail the test, tho'. Have you check to make sure the bulb is installed right side up? That would be a reason for your low beam to be shining up in the trees & your high beam to be normal... ;)
Best of luck, wish I had some helpful suggestion, but short of shimming the back of the headlight housing to tilt the beam down, I can't think of anything remotely pertinent... :huh2:
#3 John Neeson
John Neeson
    Guzzisti
  • 20 posts
  • My bike(s):
Posted 13 August 2012 - 09:45 AM
There is a locating tab on the bulb that aligns with a slot in the housing, so it can only be fitted in the correct position. It is possible that it is the wrong bulb.. I will order a new one and see if it makes any difference.
.. but short of shimming the back of the headlight housing to tilt the beam down,
The lower edge of the lamp is already hard against the fairing cut out, so it cannot be tilted down any further.
#4 John Neeson
John Neeson
    Guzzisti
  • 20 posts
  • My bike(s):
Posted 14 August 2012 - 09:32 AM
Now that I am considering all possibilities... Is the correct headlamp fitted? The lens has the following markings:
"tri.o.m 40034".
Could someone (with a UK model) confirm that is correct?
thanks
#5 Mad Farquhar
Mad Farquhar
    Guzzisti
  • 51 posts
  • My bike(s):
    Sport 1100 inj 1997, Triking 850 1989
    Black Isle, Scotland
Posted 14 August 2012 - 05:20 PM
"tri.o.m 40034".
thanks
John - check out Jamies post here for some info:-
http://www.motoguzzi...1100+sport+head
and, from this posting:-
http://realoem.com/b...621&hg=63&fg=05
I'll check the lens marking later and revert. My one suffered the adjusting tab breaking so I stuck on a metal bracket. I believe that they warp with the heat from the 60/55W bulb. Mine has a top surface (definitely dished) which no doubt throws alignment out. My problem though similar is more to do with a mod to the instruments which fouls the headlamp and prevents it "rotating up" at the back to give correct alignment. Presently looking at changing to projectors for the bike as, IMHO, the headlight is utter crap - in design and function.
Posted Image
#6 John Neeson
John Neeson
    Guzzisti
  • 20 posts
  • My bike(s):
Posted 14 August 2012 - 05:51 PM
Thanks for the info. I had heard that the BMW C1 headlamp was the same. There is one for sale on ebay right now, however it does not have the same part number. It is hard to discern the full text from the picture, but it is something like "tri.o.m 2080..."
I have to agree with your assessment: is indeed utter crap! If I can't resolve this problem, I might just remove it completeley and get a daylight MOT! I would hardly notice the difference as I only use the bike during the summer months.
#7 Mad Farquhar
Mad Farquhar
    Guzzisti
  • 51 posts
  • My bike(s):
Posted 14 August 2012 - 07:07 PM
How about running the whole caboodle through a bandsaw to get the lens off the pathetic black plastic silvered bit then moulding a new piece to fit with better adjustment? Just a thought... new LHD ones are over £100 - scary, but then it is from Built Minus Wit.
#8 John Neeson
John Neeson
    Guzzisti
  • 20 posts
  • My bike(s):
Posted 14 August 2012 - 11:18 PM
Liked your idea about a projector conversion. Have you scoped out the work involved yet?
Alternatively, this round lamp conversion looks good - if you are good at moulding GRP.
#9 Wits
Wits
    Rookie
  • 14 posts
  • My bike(s):
    1100 sport inj 1999 Loud!! Sold Now 1100 Breva
    Shropshire UK
Posted 14 August 2012 - 11:31 PM
The BMW C1 headlight is same as the Guzzi 1100 sport. The can be purchased from Motor works Homeforth part number 63122350525 £94.54p inc vat +carriage special order (2010 price) parts list http://realoem.com/b...g=63&fg=05&hl=2
also look at changing the wiring to head light look at http://ebbo.org/headlamp_relays.php.
Made up this loom cost about £20.00 using good relays etc just need time to fit and test
Mangaed to get a spare headlamp from e blag for £30:00p inc postage from germany
cheers wits
#10 John Neeson
John Neeson
    Guzzisti
  • 20 posts
  • My bike(s):
Posted 18 August 2012 - 11:15 PM
cheers wits
I bought the C1 headlamp from ebay. It is NOT the same as the Guzzi part, however it is similar enough to fit. One significant difference - I hope- is the bulb orientation.
I have booked an MOT on Wednesday. Fingers crossed!
Edit: Tried to post a picture. No luck!
#11 Mad Farquhar
Mad Farquhar
    Guzzisti
  • 51 posts
  • My bike(s):
Posted 19 August 2012 - 12:26 AM
Take some black insulation tape - you may have to mask the lens if it's a european version - a "nice" MOT tester will allow that.
#12 John Neeson
John Neeson
    Guzzisti
  • 20 posts
  • My bike(s):
Posted 19 August 2012 - 12:21 PM
AFAIK its from a UK bike. A black bin liner will be more useful if it is as bad as the original.
#13 John Neeson
John Neeson
    Guzzisti
  • 20 posts
  • My bike(s):
Posted 23 August 2012 - 01:08 PM
Update: Passed the MOT! Only after the tester masked off part of the lens with black tape. Maybe the C1 headlamp was not from a UK bike after all.
Would still like to do more permanent fix. Maybe a project for the winter.
#14 Mad Farquhar
Mad Farquhar
    Guzzisti
  • 51 posts
  • My bike(s):
Posted 23 August 2012 - 09:17 PM
S'funny that - my ST1100 is a (German?) import and to change the headlight assembly would be expensive so I taped the area off and my sympathetic MOT tester wasn't blinded - all happy. Why bother change out if you don't drive at night? Once I get the projectors sorted out I'll let you see them - long term, back of the bench, at the moment.
Great run today from home to Strathcarron over to Kintail, down to Invermoriston, Fort Augustus, then Inverness via the south side of Loch Ness and into my mums for coffee before a severe wild thrash home. 185 miles and boy do my hips know it!
#15 Mad Farquhar
Mad Farquhar
    Guzzisti
  • 51 posts
  • My bike(s):
Posted 28 August 2012 - 03:26 PM
Current mock up of projectors and trial possible carbon fibre infill. Still not sure of the aesthetics for the front end - wonder if they will fit in the air intakes now I have K&Ns fitted - things that make you go mmmm....
Posted Image
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
