IPB Style© Fisana
TPS/ Throttle Balance Question
  • Please log in to reply
7 replies to this topic
#1 bentfab
bentfab
    Rookie
  • 13 posts
  • My bike(s):
    V11 Sport, 2000
    Houston TX
Posted 20 August 2012 - 02:15 PM
Hey guys,
After adjusting the valves this weekend I decided I should finally break down and adjust the TPS and sync the throttle bodies. Had avoided TPS adjustment in the past because it seemed intimidating, but after reading over the instructions I found here I gave it a try and had the bike running better than it has in years in less than 45 minutes. Thanks!
One question though. The air by pass screw on both of my throttle bodies have almost no resistance and I'm afraid they will vibrate out of sync on my first ride. I thought about backing them all of the way out (do they come all of the way out?) and putting a dap of thread loc on them before re-syncing.
Any reason this is a bad idea? Anyone have a better solution?
Thanks
#2 gstallons
gstallons
    "I live here"
  • 2,057 posts
  • My bike(s):
    1987 lemans se 2003 v11 sport 1985 bmw k100rs
    wickliffe ky
Posted 20 August 2012 - 03:14 PM
The thread locker is a permanent solution. I don't think you want that. Maybe a pipe thread sealant or something like that?
#3 Baldini
Baldini
    "I live here"
  • 2,865 posts
  • My bike(s):
    '02 Scura , '77 950 .
    Maldwyn/Montgomeryshire. Cymru
Posted 20 August 2012 - 03:52 PM
...Had avoided TPS adjustment in the past because it seemed intimidating, but after reading over the instructions I found here I gave it a try and had the bike running better than it has in years in less than 45 minutes....
I have same phobia - never touched FI, always took it to a man who knew. Your words are an inspiration! Which instructions did you follow? Thanks.
KB :sun:
#4 bentfab
bentfab
    Rookie
  • 13 posts
  • My bike(s):
    V11 Sport, 2000
    Houston TX
Posted 20 August 2012 - 04:03 PM
KB :sun:
In the FAQ section there is an article called "TPS Setup and Throttle Balance Tuning how to set your TPS and balance throttle bodies".
When I finally figure out that mV = milli volt, or 150mV = .15 volts it all clicked. I borrowd a Twin Max electronic carb adjuster from one of the Harley riders in the shop next door. Easier to use than mercury sticks.
#5 bentfab
bentfab
    Rookie
  • 13 posts
  • My bike(s):
    V11 Sport, 2000
    Houston TX
Posted 20 August 2012 - 04:04 PM
I was going to use the blue thread loc. The paste, not the liquid. Makes things snug, but not permenant.
#6 gstallons
gstallons
    "I live here"
  • 2,057 posts
  • My bike(s):
    wickliffe ky
Posted 20 August 2012 - 04:20 PM
When you understand the proper sequence, it will be snap to do.
#7 bentfab
bentfab
    Rookie
  • 13 posts
  • My bike(s):
    V11 Sport, 2000
    Houston TX
Posted 20 August 2012 - 06:04 PM
Just took a test spin! Pulls hard from low rpm's like a twin should and really smoothed out that mid level flat spot! Also got rid of that terrible rat-a-tat-tat out of the exhaust that the Harley guys love so much when you back off the throttle.
#8 docc
docc
    "I live here"
  • 3,993 posts
  • My bike(s):
    2000 V11 Sport
    middle Tennessee, USA
Posted 21 August 2012 - 04:35 AM
While I do use a "jam nut" on the white linkage knob, I've never found my air screws to walk. I favor the "full turn" setting and always find them where I left them last.
I do like using the mercury sticks, partly for their socially unacceptable danger (my kids do seem a bit odd at times), but for their atavistic appeal - how could anyone tune a 2 valve, push rod twin any other way? :oldgit:
Motowfo and I had some fun balancing his Coppa with the TwinMax and then checking it with the mercury sticks . . . . it was perfect and the mercury would make it no better. I'm sure I broke numerous transport regulations just driving the scary things across county lines on federal highways, but it was worth it to report that the digital solution is reliable and more than adequate.
That, and I had been plied with Imperial Stout . . . :drink:
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
