After finding the threaded connectors were not for the V11LM/S I fitted the Nissan application and began to research.
I found extremely helpful technical assistance from a fellow (motorcyclist) at Pureoil (Purolator filters). He was very patient with my series of e-mails and provided me with dimensioned diagrams and the following technical specifications:
The filters do all, generally, filter 7-11 microns (Guzzi calls for 10 microns) and are tested at 4 bar (58 psi). Guzzi FI runs 3 bar +/- 0.2 (41 - 46 psi). So, filtration and pressure should be covered.
This brings us to the issues of surface area and flow rate. The "Nissan" filter ( Purolator F43178) has 630cm2 surface area and flows 24 gallons per hour (the OEM Weber has 1200 cm2 and probably flows more like 45 gph). Remember that the closed loop FI flows unused fuel back to the tank through the pressure adjuster on the right side of the tank so that the majority of fuel flowed is not injected but returned.
If you fit the "Nissan" filter it is much shorter and requires a longer fuel line from the pump. In searching for a longer filter for increased flow and surface area I found the following alternatives (again, Purolator numbers):
F54718 used on Dodge Dakota V6/V8 is longer and has a bracket to be removed. More expensive due to the bracket ($11US)
F67221 is LAZER welded to hold 300 psi, flows 45 gph and has 580 cm2 surface area. It is 5 3/4 inches long and should be the closest in overall dimension to the Weber. I'm not sure what its application is but I will check and post back. (Around $8 compared to the Weber from Guzzi at $33US).
The F67221 is a better choice than the"Nissan" (F43178) due to its strength and dimension (may still require a longer fuel line). They'll probably both work just fine.
Realize that less surface area means shorter service interval. Guzzi says 12000miles so a 6000 mile interval is extremely conservative for the smaller filter.
If you made it this far on this post, congatulations, you are now a 'certifiable' techno-head!
Sign In
Register
Help
MultiQuote
0.2491 sec
25
