Guest bird Posted February 24, 2008 Share Posted February 24, 2008 Can I use a t-3 transmission on a Lemans IV? Same 2mm clutch hub, straignt bolt on or ant modifications necessary? Link to comment Share on other sites More sharing options...
raz Posted February 24, 2008 Share Posted February 24, 2008 Can I use a t-3 transmission on a Lemans IV? Same 2mm clutch hub, straignt bolt on or ant modifications necessary? Bird, while you are welcome here this is really a spine-frame V11 forum. Your chances of getting answers for your questions will probably be much higher at Guzzi Exchange or GuzziTech.com Link to comment Share on other sites More sharing options...
macguzzi Posted February 24, 2008 Share Posted February 24, 2008 no problem same box and ratio you could look at a 1100 sport box as well Link to comment Share on other sites More sharing options...
gilerasaturno Posted March 1, 2008 Share Posted March 1, 2008 Bird, while you are welcome here this is really a spine-frame V11 forum. Your chances of getting answers for your questions will probably be much higher at Guzzi Exchange or GuzziTech.com Hi, Yes definitely. Same gear ratios, etc., same case, rear cover and gasket..... Only difference is breather hose position. It's more towards the back on the LM IV and Guzzi plugged up (neatly) the leftover breather side hole from previous models which even included the LM II. No real difference at all. Bolts right on. 4 mm hub is better overall too. Need one? I have one in Brooklyn 11204 garage with all great sharp teeth, etc., etc. pinomanusa@hotmail.com Pics too. Only charge postage, never handling. $385.00 complete! including new rear gasket plus postage and some ins. Jose'/NYC-Manhattan Link to comment Share on other sites More sharing options...
