Brivmora 0 Posted December 26, 2020 Report Share Posted December 26, 2020 Does anyone know if a piston/cylinder set from a V1100 Griso 2 valve engine will work in V11 Sport engine? Quote Link to post Share on other sites
docc 3,395 Posted December 26, 2020 Report Share Posted December 26, 2020 Pretty sure our treasured Aussie friend, @pete roper , has this expertise. I'm not certain, but I think Bungendore is in the future. As in, it's tomorrow there when it's today here. In the meantime, we can kick this around on this side of the Date Line . . . Welcome to the best place in the world for the care & feeding of your 2001 V11 Sport, Brivmora! 1 Quote Link to post Share on other sites
pete roper 473 Posted December 26, 2020 Report Share Posted December 26, 2020 I've no idea to be honest I'd think the main things to check would be rod length, deck height and stroke but there is also the matter of weight and balance. 1 Quote Link to post Share on other sites
Brivmora 0 Posted December 26, 2020 Report Share Posted December 26, 2020 Thanks. I compared the pistons and the Griso piston and its is 6mm shorter than my V11 Sort piston. The rod length must be different since the cylinder deck height is the same. Not sure where to source a pair of rods. Bore and stroke is stated as 92/80mm on both engines. Quote Link to post Share on other sites
Lucky Phil 1,785 Posted December 26, 2020 Report Share Posted December 26, 2020 23 minutes ago, Brivmora said: Thanks. I compared the pistons and the Griso piston and its is 6mm shorter than my V11 Sort piston. The rod length must be different since the cylinder deck height is the same. Not sure where to source a pair of rods. Bore and stroke is stated as 92/80mm on both engines. When you say the piston is "shorter" do you mean the compression height of the piston? I'd be surprised if the Griso has longer rods than a V11. Ciao Quote Link to post Share on other sites
Brivmora 0 Posted December 27, 2020 Report Share Posted December 27, 2020 Yes, the compression height is shorter. If I can find the dimensions on the Griso rod I could compare to my V11 Sport rod. The compression ratio would be way off if I installed them as is in the V11 engine. Maybe the crank is different? Quote Link to post Share on other sites
Lucky Phil 1,785 Posted December 27, 2020 Report Share Posted December 27, 2020 4 hours ago, Brivmora said: Yes, the compression height is shorter. If I can find the dimensions on the Griso rod I could compare to my V11 Sport rod. The compression ratio would be way off if I installed them as is in the V11 engine. Maybe the crank is different? Ok surprising. You can always count on Guzzi to throw you a curve ball. If the stroke and cylinder height is the same as the V11 then it has to be the rods that are longer. Ciao Quote Link to post Share on other sites
docc 3,395 Posted December 27, 2020 Report Share Posted December 27, 2020 9 hours ago, Lucky Phil said: Ok surprising. You can always count on Guzzi to throw you a curve ball. If the stroke and cylinder height is the same as the V11 then it has to be the rods that are longer. Ciao "Gambalunga!" Quote Link to post Share on other sites
gstallons 705 Posted December 28, 2020 Report Share Posted December 28, 2020 On 12/26/2020 at 8:51 AM, Brivmora said: Does anyone know if a piston/cylinder set from a V1100 Griso 2 valve engine will work in V11 Sport engine? Are you sure you want to do this ? Unless someone else has done it successfully , IDK if I would go there . 1 Quote Link to post Share on other sites
Join the conversation
