raz Posted November 20, 2008 Author Share Posted November 20, 2008 I too sometimes experience back-kick when cranking even though I do have TDCWhileCranking=1. It's not a big problem so I haven't looked into it but it may be that right when the ECU thinks we're up'n'running and start using the map, there is a bit too much advance. But right now I'm more concerned about the weak starter. I'll clean the solenoid and plunger first, and see what happens. Regarding air filters and open exhausts I was puzzled to see the tiny difference in mapping between all-original exhaust and full Mistrals. I think the air filter makes much more difference in mapping. I have a brand new pair of K&N pods on my kitchen table right now, we'll see what difference they will do. Frankly I bought them for the looks and sound only, if there is any performance benefit at all it's just a bonus. Link to comment Share on other sites More sharing options...
luhbo Posted November 21, 2008 Share Posted November 21, 2008 ...I was puzzled to see the tiny difference in mapping between all-original exhaust and full Mistrals. .... The originals are close to optimal and if you compare their noise emission to that of Mistrals they are really astonishing. At midrange revs they're even better in my eyes. The only problem with them: heavy, ugly, and without any discussion just too silent. (BTW, Lafranconi delivers to BMW - that speaks for itself. They're doing a very good job). To keep the posting topic related: on my bike the Optimiser shows clearly that without the rubber intake nozzles in front of the airbox/filterhousing remarkable less fuel is needed to achieve the same AFR. I'm curious what results your experiments with single pod filters will bring. I bet the results will be worse than those with standard air box. Hubert Link to comment Share on other sites More sharing options...
emry Posted November 21, 2008 Share Posted November 21, 2008 Here is the fuel table from the orginal map. RPM 500 1100 1500 1801 2000 2302 2601 2900 3360 3654 4045 4655 5353 6157 7082 8143 InjDur 14 3984 11408 11296 11008 10848 10672 10464 10288 10400 10368 10064 9920 10656 12016 11712 11376 InjDur 13 3984 11360 11248 10960 10800 10640 10416 10224 10320 10304 10032 9856 10496 11696 11392 11136 InjDur 12 3984 11280 11136 10848 10688 10544 10320 10096 10144 10128 9936 9712 10128 10944 10640 10608 InjDur 11 3984 10960 10816 10624 10512 10304 10048 9824 9696 9552 9200 8544 8624 8960 8592 8480 InjDur 10 3984 10736 10592 10512 10464 10144 9888 9664 9424 9120 8528 7952 8112 8256 7280 6864 InjDur 9 3984 9360 9248 9120 9056 8816 8592 8384 8272 8096 7680 5616 5984 6256 5888 5520 InjDur 8 3984 7968 7872 7712 7632 7456 7280 7104 6768 6416 5856 5312 4960 4784 4736 4160 InjDur 7 3984 7888 7616 7488 7424 7200 7024 6896 6512 6048 5248 4576 4576 4496 4432 4016 InjDur 6 3984 7840 7200 7056 6976 6400 6112 5920 5728 5136 4976 4576 4048 3920 3616 3872 InjDur 5 5184 7072 6608 6240 6032 5168 5104 5104 4912 4640 4176 4016 3520 3632 3184 2848 InjDur 4 4880 5168 5440 4976 4816 3872 4080 4240 4000 3872 3696 3152 2896 3040 2912 2480 InjDur 3 4688 4016 4128 4128 4128 3456 3456 3344 3248 3024 2864 2832 2464 2208 2112 2080 InjDur 2 4640 3456 3312 3312 3312 2880 2800 2704 2592 2592 2256 1936 1600 1504 1504 1504 InjDur 1 4544 2880 2880 2464 2400 2192 2016 1872 1776 1440 1472 1184 1040 1040 912 752 InjDur 0 4032 2128 1648 1680 1392 1168 1200 1200 1136 1040 1040 992 992 992 752 608 Here is the current. The lower TP angles were set using an EGA so they are pretty close. RPM 500 1150 1322 1520 1750 2011 2314 2662 3059 3521 4045 4655 5353 6157 7082 8116 InjDur 14 4912 13088 12960 12672 12480 12336 11232 11008 11056 12056 12277 12220 12540 12056 12052 12020 InjDur 13 4912 12832 13232 13040 12912 12688 11504 11264 11136 10992 11858 11500 10516 10368 10000 9872 InjDur 12 4912 12592 13008 12912 12848 12480 11328 11104 10864 10544 10908 10797 9772 9632 9608 9088 InjDur 11 4912 11136 11488 11344 11280 10992 10848 9776 9664 9456 10464 10038 8972 8972 8972 8972 InjDur 10 8720 9632 9936 9760 9680 9456 9856 8432 8464 8400 9724 9724 8800 8800 8800 8892 InjDur 9 8720 9504 9648 9504 9424 9168 9568 8208 8464 7920 9167 9167 8320 8328 8304 8032 InjDur 8 8720 9296 9088 8928 8848 8304 8816 8224 7184 7840 7926 9075 7840 7840 7840 7824 InjDur 7 6096 8736 8736 8736 8736 7104 8128 7088 7104 6784 7648 8760 7568 7568 7568 7568 InjDur 6 5808 8320 8320 8320 7728 6752 6752 6752 7008 6608 6389 7315 6320 6320 6320 6320 InjDur 5 7152 7520 7520 7312 6016 6016 6016 6016 5712 5248 5630 6389 5520 5328 5136 5136 InjDur 4 5920 6528 6640 5664 4816 4336 4752 4528 4912 4576 5110 5129 3856 3664 4304 4096 InjDur 3 5872 5920 5520 5552 4240 4176 4048 4464 4605 5196 5827 5080 3924 3763 4067 3960 InjDur 2 5824 5456 5184 4608 3872 3600 3296 3488 4659 3996 3673 3834 3548 3404 3351 3351 InjDur 1 2560 3696 3472 3280 3008 2256 2240 2528 2885 2849 3279 3082 2920 3405 3504 3220 InjDur 0 2768 2832 2928 2400 2480 2544 2608 2672 3064 3136 3207 3297 3368 3440 3512 3046 And here is a percent change. RPM 500 1150 1322 1520 1750 2011 2314 2662 3059 3521 4045 4655 5353 6157 7082 8116 InjDur 14 23.3% 14.7% 14.7% 15.1% 15.0% 15.6% 7.3% 7.0% 6.3% 16.3% 22.0% 23.2% 17.7% 0.3% 2.9% InjDur 13 23.3% 13.0% 17.6% 19.0% 19.6% 19.2% 10.4% 10.2% 7.9% 6.7% 18.2% 16.7% 0.2% -11.4% -12.2% InjDur 12 23.3% 11.6% 16.8% 19.0% 20.2% 18.4% 9.8% 10.0% 7.1% 4.1% 9.8% 11.2% -3.5% -12.0% -9.7% InjDur 11 23.3% 1.6% 6.2% 6.8% 7.3% 6.7% 8.0% -0.5% -0.3% -1.0% 13.7% 17.5% 4.0% 0.1% 4.4% InjDur 10 118.9% -10.3% -6.2% -7.2% -7.5% -6.8% -0.3% -12.7% -10.2% -7.9% 14.0% 22.3% 8.5% 6.6% 20.9% InjDur 9 118.9% 1.5% 4.3% 4.2% 4.1% 4.0% 11.4% -2.1% 2.3% -2.2% 19.4% 63.2% 39.0% 33.1% 41.0% InjDur 8 118.9% 16.7% 15.4% 15.8% 15.9% 11.4% 21.1% 15.8% 6.1% 22.2% 35.3% 70.8% 58.1% 63.9% 65.5% InjDur 7 53.0% 10.8% 14.7% 16.7% 17.7% -1.3% 15.7% 2.8% 9.1% 12.2% 45.7% 91.4% 65.4% 68.3% 70.8% InjDur 6 45.8% 6.1% 15.6% 17.9% 10.8% 5.5% 10.5% 14.1% 22.3% 28.7% 28.4% 59.9% 56.1% 61.2% 74.8% InjDur 5 38.0% 6.3% 13.8% 17.2% -0.3% 16.4% 17.9% 17.9% 16.3% 13.1% 34.8% 59.1% 56.8% 46.7% 61.3% InjDur 4 21.3% 26.3% 22.1% 13.8% 0.0% 12.0% 16.5% 6.8% 22.8% 18.2% 38.3% 62.7% 33.1% 20.5% 47.8% InjDur 3 25.3% 47.4% 33.7% 34.5% 2.7% 20.8% 17.1% 33.5% 41.8% 71.8% 103.5% 79.4% 59.3% 70.4% 92.6% InjDur 2 25.5% 57.9% 56.5% 39.1% 16.9% 25.0% 17.7% 29.0% 79.7% 54.2% 62.8% 98.0% 121.8% 126.3% 122.8% InjDur 1 -43.7% 28.3% 20.6% 33.1% 25.3% 2.9% 11.1% 35.0% 62.4% 97.8% 122.8% 160.3% 180.8% 227.4% 284.2% InjDur 0 -31.3% 33.1% 77.7% 42.9% 78.2% 117.8% 117.3% 122.7% 169.7% 201.5% 208.4% 232.4% 239.5% 246.8% 367.0% Link to comment Share on other sites More sharing options...
luhbo Posted November 21, 2008 Share Posted November 21, 2008 Ok, the changes look impressive. But do you really need them? I say most of the changes you've done to the bottom line for instance or those done to the 1100 column are just useless. What makes you think you need that much fuel when you have the throttle closed? Or do cells 7 or 8 in the 1100 column really have to do with driveability or starting problems? To keep it fair: I think those are the maps you've received from other guys, aren't they? A map sent to whoever here from Cliff is probably as good as every other map spread by me or other people. What makes you think that on my bike the basics are set up the same way as on your's? How can you know the one coming from let's say Caymans comes closer or is more suitable? Before you make any changes to the map or even have the idea of mixing parts of different maps (sort of a MyEcu Euro Cocktail) make one thing very sure: you really understand each part of this MyEcu map and how they interact and also you have your bike properly set up and properly running with the stock ECU. Some have wildly changed maps and like to complain that things aren't working as they expected. No problem so far, but how come they have so much questions about how the map works? This makes no sense, right? If a bike pops, feels really lean or has no stable idle with the standard ECU then one shouldn't expect the MyEcu to cure these problems, the more if a standard map coming from a better running bike should to the trick. This can't work. Hubert Link to comment Share on other sites More sharing options...
emry Posted November 21, 2008 Share Posted November 21, 2008 But do you really need them? Unridable, before, Enjoyable now. Yes. To keep it fair: I think those are the maps you've received from other guys, aren't they? I already thanked and credited those individuals. A map sent to whoever here from Cliff is probably as good as every other map spread by me or other people. What makes you think that on my bike the basics are set up the same way as on your's? How can you know the one coming from let's say Caymans comes closer or is more suitable? That was my orginal point. If a bike pops, feels really lean or has no stable idle with the standard ECU then one shouldn't expect the MyEcu to cure these problems, the more if a standard map coming from a better running bike should to the trick. This can't work. Lubho, the OEM ECU would give me a CO reading of 0.02% at idle. A little lean. MyECU did cure those problems because I can adjust the Inj.Dur. until I got a 3.2% reading and a nice clean idle. I seemed to have gotten under your skin somehow. Many apologies, I was just letting those intrested know that stock maps don't always work. Link to comment Share on other sites More sharing options...
luhbo Posted November 21, 2008 Share Posted November 21, 2008 No no, Emry, stay relaxed. You cannot come close to my skin, not to say under my skin. My stuff is working, since 2004. Interesting times nevertheless. Hubert Link to comment Share on other sites More sharing options...
Cliff Posted November 22, 2008 Share Posted November 22, 2008 Hello all. Believe it or not I've only just become aware of this thread. The main problem I picked up is that of documentation. This has been a weakness of mine and even in this thread I see most of you doing a better job. I also notice that this thread, in bringing you all together, has become a great resource to you. Perhaps going forward, a dedicated forum might be a good idea. Wiki was also mentioned but I'm not familiar with this. Your feedback is always welcome. Link to comment Share on other sites More sharing options...
raz Posted November 22, 2008 Author Share Posted November 22, 2008 Welcome, Cliff! A dedicated forum would be great. This single thread would get very long and hard to digest in the long run. And I guess we're only reaching some 10-15%, or less, of the user base right now. Link to comment Share on other sites More sharing options...
kadavere Posted November 22, 2008 Share Posted November 22, 2008 I may be wrong but as far as I know the software/firmware is the same for MyP8, My16M and My15M. The electronics are basically the same too, with varying PCB and form factor. Most people are having the opposite experience than you have, that is the MyECU software is very well behaved. I think you will be quite happy as soon as we can nail what is wrong. Since you already run closed loop I'm puzzled it does not work better. Of course there is a theoretical chance something is wrong with your ECU, or the LC-1 setup. But my guess is we just have a map problem. You should confirm that the output from the LC-1 analog is what you think it is. Just connect a computer with Logworks software to the digital channel and verify the the digital readout matches the Optimizer O2 reading. Then, a MyECU log would be invaluable for us! If you could supply that, we could easily compare what is different between the P8 and the MyP8, as well as correlate LC-1 readings with various throttles. If you can't get HyperTerminal, there are other good serial terminal emulators for free download on the Internet. Meanwhile, what does the Optimizer tell you when running? Is it continuosly applying a correction factor? How much? What is the O2 voltage at idle? And at open throttle? You are in posession of wonderful tools, I predict a happy future Hi raz!! I work like a damned,after my true work i run in the night with the bike! The closed loop work fine,no problem,after the tuning optimiser does not show too much correction,tanks for the suggestion,i try to connect Logworks for see if i have a offset voltage applied. I'm a donkey,i found Hyperterminal but i don't find the function for start a record..... Maybe i find somethig....the motor anwer more fast,but i dont want to scream Eureka! Ivan Link to comment Share on other sites More sharing options...
kadavere Posted November 22, 2008 Share Posted November 22, 2008 Ivan,take your time and take it easy. If you apply for help we should find a common agenda and look together what steps in what order showed what effect. The MyEcu stuff works pretty well as so often mentioned already, at least by me, but if you have all possibilities to change everything things can end up pretty weird as well. It's a complex thing. I suggested to try the unit in open loop first. The reason is, I wouldn't trust the LC1, I wouldn't trust the location of the probe and also it's not said that the exhaust is as tight as it should be. Also, as Raz has mentioned, an eventual correction factor implied by either an unsuitable map-cell or an unreliable O2 signal can make things even more confusing. Please try out the above step and report how things went. Before that you should have adjusted the TPS according to the book, also the valves, and a solid synchronisation would be helpfull as well. Then take the map that was sent to you by Cliff and don't alter anything besides the TPS offset. This map will work. Someone else already had it on his bike, if not Cliff himself, and your bike is exactly the same. By the way, I'm sure I could download it to my V11 and also had a well usable bike (as long as the TPS characteristics are the same). I can understand your feelings. When I got mine I thought everything was possible now, having insight and software and so. Then I had to learn that changing less is often more. What I've learned years before that was the funny fact that for fueling the same applies: less is more. One can easily make the fault to overly enrich the mixture where staying on the leaner side would have shown better effects. Hubert Hello Hubert!!! Yes,now i work in open loop,i don't want to put too much problem over my shoulder...something happens,i change the fist cell of the table"InjAdv"......is more fast the answer....... I have to work again to my bike.... Tank to all for the great help give to me!! Ivan Link to comment Share on other sites More sharing options...
kadavere Posted November 22, 2008 Share Posted November 22, 2008 I have not had the chance to really ride and test my maps. But the map I originally got from Cliff was unusable. Period. I used Raz's and Pasotib's maps, thanks for posting it by the way!!! You save me much trial and error. At least got me running. So serious tuning later I have a decent map, with a few oddities still, but time will solve those. Welcome to the fourm Kadavere!! Your posts are help full and I LOVE the bar graph!!!! Very slick(good) As you have found out this is the place for real assistance. I wish I had more to contribute. Best of luck. Hello emry!!! I have you same problem,the beginner map was unusable too,i use this for apply the tips and tricks i found in this forum....help me to much,i come here after many hours and thousand of kilometers of test,now work more better but i think the way for the perfection need more time and work from me....... Tanks Ivan Link to comment Share on other sites More sharing options...
greenmonster Posted November 22, 2008 Share Posted November 22, 2008 Welcome, Cliff, good to have you with us! How much fuel is it getting during cranking for start at 20 degrees C? Is it like (figures fr standard Cliff Cali map, cold engine): 4500ms (column 1/500 RPM, 2nd TPS) + Air temp boost (+ 3,4% at 20 degrees) + Oil temp choke boost (+18,8% at 20d) + Prime while cranking 12 ms? 5502 ms if so seems quite alot. Or is it normal? Or have I misunderstood something? # Prime gives the fuel injection time in ms while cranking From a MyECU map, what does that mean? Link to comment Share on other sites More sharing options...
raz Posted November 22, 2008 Author Share Posted November 22, 2008 How much fuel is it getting during cranking for start at 20 degrees C? Is it like (figures fr standard Cliff Cali map, cold engine): 4500ms (column 1/500 RPM, 2nd TPS) + Air temp boost (+ 3,4% at 20 degrees) + Oil temp choke boost (+18,8% at 20d) + Prime while cranking 12 ms? 5502 ms if so seems quite alot. Or is it normal? Or have I misunderstood something? Note that the map says 4500 μs, that is 4.5 ms. I know you knew that if you thought about it, 4500 ms is 4.5 seconds! As I understand it (I may be wrong), while cranking you get 12 ms, period. After engine is running on its own, you'll get the map value plus a 60% start boost that decays over 20 seconds. Plus the usual oil and air temp boosts. # Prime gives the fuel injection time in ms while cranking #Temp C -30 -20 -10 0 10 20 25 30 40 50 60 70 80 90 100 110 125 Prime 30 30 25 20 17 12 11 9 8 5 4 5 # Crank is the %% boost of the map injection times right after start # this boost decays to 0 over about 20s #Temp C -30 -20 -10 0 10 20 25 30 40 50 60 70 80 90 100 110 125 Crank 80 70 65 60 60 60 55 50 35 15 10 15 15 15 15 0 # OilT is the permanent choking boost #Temp C -30 -20 -10 0 10 20 25 30 40 50 60 70 80 90 100 110 125 OilT% +64.8 +53.9 +44.5 +35.9 +29.7 +19.5 +10.2 +9.4 +5.5 +0.0 Link to comment Share on other sites More sharing options...
raz Posted November 22, 2008 Author Share Posted November 22, 2008 (edited) I'm a donkey,i found Hyperterminal but i don't find the function for start a record..... My Hyperterminal is Swedish, but the menu should be called something like "Transfer" and then you choose something like "Capture text file". Now you should be prompted to select a file name for the log. Serial parameters should be 38400,N,8,1. A proper log looks like this: =112991415FC2D14D3300000000000002300000025 =310FB03024400040000000000040000000450 =00E0D00AC012B03A5036C00BC01E3019D =112991415FC2D14D3300000000000002300000025 =310FB03024400040000000000040000000450 =00E0D00AC012B03A5036C00BC01E3019D ... And then you can load that in ECUControl and convert it to human readable (edit: load the map in ECUControl, then click the button called ECU Diagnostics, choose your dump file, and then save it (the program unintuitively says "open file" again) with a new name): Map (1.9,1.8) RPM=1446 Inj=4812us BaroAdj=106.3% o2Adj=100.0% o2[1] o2Target=0.00V o2=1.99V OilT=50.0C AirT=10.0C AirP=1019mb Thro=184 Bat=13.80V Map (2.2,1.3) RPM=1545 Inj=4569us BaroAdj=106.3% o2Adj=100.0% o2[1] o2Target=0.00V o2=2.52V OilT=50.0C AirT=10.0C AirP=1019mb Thro=180 Bat=13.89V Map (2.8,1.2) RPM=1717 Inj=4392us BaroAdj=106.3% o2Adj=100.0% o2[1] o2Target=0.00V o2=2.53V OilT=50.0C AirT=10.0C AirP=1019mb Thro=180 Bat=13.89V Map (3.7,1.1) RPM=1931 Inj=4241us BaroAdj=106.3% o2Adj=100.0% o2[1] o2Target=0.00V o2=2.52V OilT=50.0C AirT=10.0C AirP=1019mb Thro=161 Bat=13.86V Map (4.2,0.6) RPM=2044 Inj=3525us BaroAdj=106.3% o2Adj=100.0% o2[1] o2Target=0.00V o2=2.42V OilT=50.0C AirT=10.0C AirP=1019mb Thro=140 Bat=13.83V ... One suggestion for Cliff: the ECUControl program should be able to output a log file while running, so we don't need HyperTerminal. That way we also wouldn't have to choose between controlling and logging. Edited May 18, 2009 by raz Link to comment Share on other sites More sharing options...
