robert7571 Posted August 29, 2012 Share Posted August 29, 2012 1 Link to comment Share on other sites More sharing options...
docc Posted August 31, 2012 Share Posted August 31, 2012 That is such a gorgeous V11! I do live the Tennis. What are those panniers? Link to comment Share on other sites More sharing options...
fotoguzzi Posted September 2, 2012 Share Posted September 2, 2012 those are Hepko Becker bags. Link to comment Share on other sites More sharing options...
Tony Jarvis Posted January 28, 2018 Share Posted January 28, 2018 Brought this Tenni - #009 - February 2017 . Just love riding it. Wish I could find out if the clutch has been updated...Its still single plate based on the rattle! 1 Link to comment Share on other sites More sharing options...
Chuck Posted January 28, 2018 Share Posted January 28, 2018 You can tell by pulling the "timing inspection" plug and having a look up her skirt. I don't have the pix right now, but an internet search should show the difference. Congrats on having one of the prettiest Guzzis built, and welcome to the best forum in the world on them. Link to comment Share on other sites More sharing options...
Paradiso Posted January 28, 2018 Share Posted January 28, 2018 You can tell by pulling the "timing inspection" plug and having a look up her skirt. I don't have the pix right now, but an internet search should show the difference. Congrats on having one of the prettiest Guzzis built, and welcome to the best forum in the world on them. You can tell by the rattle! One type rattles with the clutch pulled in. One rattles with the clutch released. Just can't remember which is which. Scud will know. There's a thread somewhere commenting on just this. Sent from my SM-G925F using Tapatalk Link to comment Share on other sites More sharing options...
Scud Posted January 29, 2018 Share Posted January 29, 2018 Great bike. If you pull the clutch in with engine idling, and it gets quieter, you have a single-plate clutch. Most likely that means you have an original clutch and flywheel. Remember, the clutch itself is not the problem; the original aluminum flywheel is the problem. If you pull the clutch in with engine idling and it gets noisier, you have a standard, twin-plate clutch like most V11s. The noise is caused by the pressure plate backing off and allowing the many parts to rattle around inside the flywheel. I am not sure what causes the noise at idle on the single plate. But we do know it's a risk factor. It's a relatively low probability that your aluminum flywheel will explode, but the consequences are potentially very bad. There's lots of information and speculation about the single plate clutch/flywheel. Now if you're wondering if the bike was updated with a Ram single plate clutch and steel (not aluminum) flywheel, you'd need to get a magnet on the flywheel. I think this could be done with some sort of magnet on a flexible stick. You could try through the timing hole... but it might require removing the starter to get access. Also, the aluminum flywheel is round, while the Ram steel flywheel has three arms. 1 Link to comment Share on other sites More sharing options...
r3datom9 Posted January 30, 2018 Share Posted January 30, 2018 Congrats on the Tenni What kinda mileage on her? Link to comment Share on other sites More sharing options...
Tony Jarvis Posted February 8, 2018 Share Posted February 8, 2018 Thanks for the responses.Its single plate - based on the rattle in neutral - clutch out.I have been told by Mario at Thunder Bikes the noise on the single plate is actually from the gear box - probably doesn't matter its just Guzzi normal!As Scud suggested I was hoping to find some way of establishing if the flywheel has been updated.The idea for testing if its a steel RAM flywheel with a magnet or visually seeing the shape sounds the best starting point.My Tenni has 39,000 Km on it and the clutch performs without any signs of wear , vibration or noises so I expect it is fine.However at the Phillip Island Classic a couple of weeks ago I met the original owner of Tenni #4 and his flywheel started make noises and jamming in gear at 20,000km so the panics have set in. (His flywheel had radial cracking).About to set off on the Victorian Moto Guzzi Club tour of Tasmania - 2500 km of tight twisting tarmac and some dirt in a week. Tenni heaven. 1 Link to comment Share on other sites More sharing options...
LowRyter Posted February 8, 2018 Share Posted February 8, 2018 I think they all rattle in neutral. Maybe it's a different rattle? Link to comment Share on other sites More sharing options...
docc Posted February 8, 2018 Share Posted February 8, 2018 I think Scud, or *maybe* footgoose, should give us a side-by-side video tutorial on this rattle business . . . I'll pin it somewhere and we'll have a time with it! Link to comment Share on other sites More sharing options...
LowRyter Posted February 9, 2018 Share Posted February 9, 2018 How far are you guys going with this? Link to comment Share on other sites More sharing options...
Scud Posted February 9, 2018 Share Posted February 9, 2018 I think Scud, or *maybe* footgoose, should give us a side-by-side video tutorial on this rattle business . . . I'll pin it somewhere and we'll have a time with it! That could be a worthy project. Meanwhile Robert needs to pack a little bottle Love Potion Tenni #9 for the Tazzy Trip. Watch the wallabies. Link to comment Share on other sites More sharing options...
LowRyter Posted February 9, 2018 Share Posted February 9, 2018 Just another reason I wear ear plugs. None of this rattle of gears and tappets, just the rumble of my Guzzi firing at 9am and midnight. 1 Link to comment Share on other sites More sharing options...
docc Posted February 9, 2018 Share Posted February 9, 2018 "9am & midnight" . . . drummer think ! Link to comment Share on other sites More sharing options...
