Walterg Posted May 22, 2015 Share Posted May 22, 2015 I have noticed that stains are appearing on the spot where I park my bike every day. I checked underneath the bike andeverything is dry except for a small drop hanging from a black tube just behind the engine case.Any ideas as to what is happening ? It looks like fuel is leaking onto the ground but why ?The stains don't appear after every ride though. Walter Link to comment Share on other sites More sharing options...
jwh20 Posted May 22, 2015 Share Posted May 22, 2015 Are you sure it's fuel and not oil or oily water? Also are you sure the drop hanging from the tube is the same stuff? Use your nose, it can tell if it's fuel or oil pretty well. My V11 would leak a bit of fuel from the bottom of the throttle bodies because the rubber boots were slightly cracked. After replacing them there is no more leak. I believe the black tube you are talking about is the crankcase breather tube, it's normal to have some slight discharge from this and it's usually oily water. There is also a fuel tank overflow tube that comes down somewhere around there. Generally should not vent fuel unless you're overfilling, have a leaking filler cap, or the cap vent is plugged and pressure is building up in the tank and pushing fuel out the overflow. Link to comment Share on other sites More sharing options...
Walterg Posted May 22, 2015 Author Share Posted May 22, 2015 Because of the colour of the stains I assumed it had something to do with fuel. I'll do a better inspection when I get home. Link to comment Share on other sites More sharing options...
rossi46 Posted May 22, 2015 Share Posted May 22, 2015 that tube that comes out at the back of the engine should be(i think) the fuel overflow I guess if you really filled the tank just before parking it could dribble out when on the s/stand? Link to comment Share on other sites More sharing options...
Walterg Posted May 29, 2015 Author Share Posted May 29, 2015 I don't think it's from the fuel overflow in the tank because I just found out that it's clogged up ! Link to comment Share on other sites More sharing options...
fotoguzzi Posted May 30, 2015 Share Posted May 30, 2015 I don't think it's from the fuel overflow in the tank because I just found out that it's clogged up ! so the tank might be sucking and vents it out after you stop riding.. do you hear a swoosh when you open the cap? Link to comment Share on other sites More sharing options...
