Itsagas Posted May 19, 2016 Share Posted May 19, 2016 Hi all, I'm trying to find a tail tidy or template to make one. I've found a couple of posts but have been unable to find anything. Can you guys assist? Regards Dean Link to comment Share on other sites More sharing options...
Scud Posted May 19, 2016 Share Posted May 19, 2016 I think there are many good examples, with descriptions of how people did it various posts. A little more searching might turn up some more examples. Here is a template I downloaded from one such post on this forum, but I don't recall who created it. I attached it for you here. V11 Sport Fender Eliminator Bracket (preliminary).PDF I didn't end up using this template, because I was happy enough with cutting the stock fender down a bit and installing much smaller, LED turn signals. Link to comment Share on other sites More sharing options...
Jet Posted May 21, 2016 Share Posted May 21, 2016 I am going to have a slightly modified FBF tidy tale I could give away in a couple weeks......but as I write this i notice you in Australia, and the shipping might not be worth the squeeze. Link to comment Share on other sites More sharing options...
mznyc Posted May 26, 2016 Share Posted May 26, 2016 I am going to have a slightly modified FBF tidy tale I could give away in a couple weeks......but as I write this i notice you in Australia, and the shipping might not be worth the squeeze. I'd be interested in it Jet,.... Link to comment Share on other sites More sharing options...
footgoose Posted November 29, 2020 Share Posted November 29, 2020 2020 update! This tidy came on my since parted out '03 RC. 2 1 Link to comment Share on other sites More sharing options...
footgoose Posted November 29, 2020 Share Posted November 29, 2020 I think someone on WG posted there and was making them several years ago. I can't find any recent activity so I don't feel out of line posting this. I made a template of the two pieces. Pretty straight forward. Cut and bend. The main piece is s/s and could be made in different dimensions to fit different lighting. The smaller piece is thin alm and has 2 mounting holes. Slight bending to fit contour and only serves as a mudguard. All pieces attach to existing frame mounts. Looking up at the mudguard Sorry the other small hole on the mudguard is hard to see 1 Link to comment Share on other sites More sharing options...
footgoose Posted November 29, 2020 Share Posted November 29, 2020 One more angle 2 Link to comment Share on other sites More sharing options...
footgoose Posted November 29, 2020 Share Posted November 29, 2020 the whole thing attaches to existing frame bracket which you'll see when you get all the other crap outta the way. 2 bolt holes on the tab you bend down from the center of the license plate area 1 Link to comment Share on other sites More sharing options...
Vic Posted November 29, 2020 Share Posted November 29, 2020 Very nice! Why the 4 holes along the bend line,seems like this would make it more prone to cracking along this line? Link to comment Share on other sites More sharing options...
footgoose Posted November 29, 2020 Share Posted November 29, 2020 It's heavy stainless. My guess it makes it easier to bend, and on a line Link to comment Share on other sites More sharing options...
nobleswood Posted November 29, 2020 Share Posted November 29, 2020 Footgoose, thanks for posting that; I like how that tail tidy looks & will fabricate one similar. Who makes the indicators ? Link to comment Share on other sites More sharing options...
footgoose Posted November 29, 2020 Share Posted November 29, 2020 5 hours ago, nobleswood said: Footgoose, thanks for posting that; I like how that tail tidy looks & will fabricate one similar. Who makes the indicators ? my setup came on the bike and I think the whole thing was put together some time ago, maybe 10-15 years. I searched ebay and found these. (I have not purchased)They appear the same. Mine are nice and bright. I have not found a duplicate of the brake/taillight in any search. https://www.ebay.com/itm/Clear-Black-LED-Stalk-Turn-Signal-Universal-Light-Motorcycle-Stem-Flasher-Saber/173890735611?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649 I have small incandescent on the front till I'm bothered enough to figure out the ''led signal flash dilemma". It works that way by just swapping flasher unit. The PO of the parts bike had the signal circuit wired into the dash lamps somehow, and all 4 worked. But I didn't pay attn as to how when I tore it apart. I did see the tell-tale wire splicing later! I think KiwiRoy OR MartyNZ (sorry mates I don't recall which) has a way to wire them through a dash light (?) so all 4 flash correctly. Let me know if you need more precise measurements. the thin alm used on the mudguard is akin to flashing or window wrap used in home construction. 1 Link to comment Share on other sites More sharing options...
docc Posted November 30, 2020 Share Posted November 30, 2020 This picture does not do this V11 justice. I had the privilege of seeing this magnificent Tenni at the South'n SpineRaid and that's the tightest tail on a V11 ever. Unless you go back to that early Rev-mag photo shoot . . . 2 1 Link to comment Share on other sites More sharing options...
Lucky Phil Posted December 1, 2020 Share Posted December 1, 2020 On 11/30/2020 at 1:14 PM, docc said: This picture does not do this V11 justice. I had the privilege of seeing this magnificent Tenni at the South'n SpineRaid and that's the tightest tail on a V11 ever. Unless you go back to that early Rev-mag photo shoot . . . Personally I like this better. http://www.fastguzzi.nl/v11/scuracarbontail2.jpg Ciao Link to comment Share on other sites More sharing options...
Kiwi_Roy Posted December 1, 2020 Share Posted December 1, 2020 I like Footgoose's tail tidy, I made something similar for my Griso using the original tail-light but added some white LEDs to illuminate the plate. I just made mine of aluminium, much easier to work than stainless and holds a high polish. I think you need a rear hugger before adding the tail-tidy. Link to comment Share on other sites More sharing options...
