Chuck Posted August 7, 2016 Share Posted August 7, 2016 Hmm, went to post this and it apparently went into the ether. Typing on a strange tablet, I no doubt pushed the wrong button.. but I digress.. Coming to a stop, it shifted down normally. Leaving the stop, it shifted into second but no farther. It will go back to first, neutral, and second, but that is all it will do. It's not the shifter spring, apparently, and the linkage looks fine. Has anyone seen this before? I've never heard of it. Fortunately, Dorcia had the van in camp, so we roared back at 40 mph for 40 miles. . borrowed a ramp, and loaded the Mighty Scura in the van. Any ideas? TIA Link to comment Share on other sites More sharing options...
Lucky Phil Posted August 7, 2016 Share Posted August 7, 2016 It will be in the shift mechanism internally Chuck and without knowing the version of shift mechanism it has its hard to say. Cant se it being a big issue to fix though. Ciao Link to comment Share on other sites More sharing options...
docc Posted August 7, 2016 Share Posted August 7, 2016 LukyPhil's amazing V11 Shift Improvement thread in "How To . . . " http://www.v11lemans.com/forums/index.php?showtopic=19547 Link to comment Share on other sites More sharing options...
Chuck Posted August 7, 2016 Author Share Posted August 7, 2016 It will be in the shift mechanism internally Chuck and without knowing the version of shift mechanism it has its hard to say. Cant se it being a big issue to fix though. Ciao I was sort of afraid of that.. Ah well, I get to *fix* something.. Eventually. Link to comment Share on other sites More sharing options...
Chuck Posted August 7, 2016 Author Share Posted August 7, 2016 LukyPhil's amazing V11 Shift Improvement thread in "How To . . . " http://www.v11lemans.com/forums/index.php?showtopic=19547 Thanks, Docc.. Link to comment Share on other sites More sharing options...
GuzziMoto Posted August 8, 2016 Share Posted August 8, 2016 Also, before you dig into the internals make sure there is no binding in the external linkage. It seems simple and silly, but as it is easy to check and it could be that simple I would check it before digging in. Link to comment Share on other sites More sharing options...
Chuck Posted August 8, 2016 Author Share Posted August 8, 2016 Also, before you dig into the internals make sure there is no binding in the external linkage. It seems simple and silly, but as it is easy to check and it could be that simple I would check it before digging in. BTDT on the side of the road.. Link to comment Share on other sites More sharing options...
passator cortese Posted August 8, 2016 Share Posted August 8, 2016 I think is a gearbox preselector problem ( probably you have a torn spring or something like that) and as already told you it's not so difficult to open it and check what's wrong, before to do it mark the gearbox lever assembly,so when you put everything back together it's easier. Link to comment Share on other sites More sharing options...
Chuck Posted August 8, 2016 Author Share Posted August 8, 2016 I think is a gearbox preselector problem ( probably you have a torn spring or something like that) and as already told you it's not so difficult to open it and check what's wrong, before to do it mark the gearbox lever assembly,so when you put everything back together it's easier. I would think that if the spring was broken, the shift lever wouldn't return to the neutral position. Link to comment Share on other sites More sharing options...
passator cortese Posted August 8, 2016 Share Posted August 8, 2016 That's true, when the spring is broken the gearbox is completely locked, but there's another spring inside the preselector, or something it's stuck between the two wheels of the preselector when they try to reach the "3rd gear position". If you don't hear other weird noises form the gearbox I think the problem can be located in the preselector, but of course I'm not a mechanic!! Be careful to don't mess with the forks, spring etc in the preselector, it can be painful! Link to comment Share on other sites More sharing options...
passator cortese Posted August 8, 2016 Share Posted August 8, 2016 When you are in the second gear the shift lever is free to move like when you are in 6th gear or is it locked? Link to comment Share on other sites More sharing options...
Chuck Posted August 9, 2016 Author Share Posted August 9, 2016 When you are in the second gear the shift lever is free to move like when you are in 6th gear or is it locked? It's free to move down to neutral or first, but not up. Link to comment Share on other sites More sharing options...
Chuck Posted August 9, 2016 Author Share Posted August 9, 2016 That's true, when the spring is broken the gearbox is completely locked, but there's another spring inside the preselector, or something it's stuck between the two wheels of the preselector when they try to reach the "3rd gear position". If you don't hear other weird noises form the gearbox I think the problem can be located in the preselector, but of course I'm not a mechanic!! Be careful to don't mess with the forks, spring etc in the preselector, it can be painful! So far, I'm liking what you are saying.. I'd much rather it isn't internal. Link to comment Share on other sites More sharing options...
gstallons Posted August 9, 2016 Share Posted August 9, 2016 As Harry Nillson said "Now lemme get this straight.." You can get the transmission into neutral , you can get the transmission into 1st gear and move forward in 1st , you can get the transmission then to shift into 2nd gear and move forward in 2nd gear. Then you cannot get the transmission into 3rd gear. Is this correct ? Link to comment Share on other sites More sharing options...
Chuck Posted August 9, 2016 Author Share Posted August 9, 2016 As Harry Nillson said "Now lemme get this straight.." You can get the transmission into neutral , you can get the transmission into 1st gear and move forward in 1st , you can get the transmission then to shift into 2nd gear and move forward in 2nd gear. Then you cannot get the transmission into 3rd gear. Is this correct ? Correct. Never have heard of that. Link to comment Share on other sites More sharing options...
