Tomchri Posted April 11, 2019 Share Posted April 11, 2019 Have you found all the answers to K Roys questions ? He knows,,,, you will find it. Cheers tom. Link to comment Share on other sites More sharing options...
docc Posted April 11, 2019 Share Posted April 11, 2019 True that, on following Kiwi_Roy's advice. gatorman, If I am reading correctly, you are trying to use a starter for a California on a V11? Certainly, the flywheels are different. Enough different that those starter are incompatible? IDK. Anyone with this experience? Link to comment Share on other sites More sharing options...
gatorman Posted April 12, 2019 Share Posted April 12, 2019 3 hours ago, Tomchri said: Have you found all the answers to K Roys questions ? He knows,,,, you will find it. Cheers tom. i still have not found an answer Link to comment Share on other sites More sharing options...
gatorman Posted April 12, 2019 Share Posted April 12, 2019 i used the id number and that starter is what came up if i am using the wrong starter please point the way to find the right starter Link to comment Share on other sites More sharing options...
docc Posted April 12, 2019 Share Posted April 12, 2019 13 hours ago, gatorman said: just tried a test put model clay on the flywheel and installed the starter the teeth on the starter were bigger than the teeth on the flywheel meaning that the starter gear is to big? Original starter on a 2001 V11 would be Valeo, not Bosch. From the parts "fiche" ---> Starter motor Valeo GU30730711 Check with r3datom9 currently parting out a 2000 Sport in CA, USA. That would be the correct starter for your 2001: https://www.v11lemans.com/forums/index.php?/topic/20736-2000-sport-part-out/ Here is the V11 replacement starter that Tinus89 found in The Netherlands for 60Euro: https://www.winparts.nl/motordelen-toebehoren/startmotoren-dynamo-s/startmotor/c834/startmotor-moto-guzzi-1-2-kw/p582790.html "Aantal tanden" = 9 (tooth count) The starter you are using has 8 teeth? Link to comment Share on other sites More sharing options...
docc Posted April 12, 2019 Share Posted April 12, 2019 20 minutes ago, docc said: Original starter on a 2001 V11 would be Valeo, not Bosch. From the parts "fiche" ---> Starter motor Valeo GU30730711 Check with r3datom9 parting out a 2000 Sport. That would be the correct starter for your 2001: https://www.v11lemans.com/forums/index.php?/topic/20736-2000-sport-part-out/ Here is the V11 replacement starter that Tinus89 found in The Netherlands for 60Euro: https://www.winparts.nl/motordelen-toebehoren/startmotoren-dynamo-s/startmotor/c834/startmotor-moto-guzzi-1-2-kw/p582790.html "Aantal tanden" = 9 (tooth count) The starter you are using has 8 teeth? Also, take a look at Gordon's comments on MGCycle for the replacement starter and the "Alternate Starter": http://www.mgcycle.com/index.php?main_page=product_info&cPath=37_159&products_id=1227 Link to comment Share on other sites More sharing options...
Kiwi_Roy Posted April 12, 2019 Share Posted April 12, 2019 (edited) Thanks for weighing in Docc, I have no experience with swapping starters. Sorry it was me that mentioned Bosch, Gatorman said D6RA2 It sounds as though Gatorman has the bikes original starter as well though, that should fit I still don't know for sure he is talking about a VII or something else, we don't have the obligatory picture, LOL So it turns out to be a VII Bassa at least that's what it says on the side cover, beautuful mile muncher, the EVs had foot boards, I prefer the pegs and love those tubeless wheels, a classic Guzzi for sure. Edited April 14, 2019 by Kiwi_Roy I see the picture Link to comment Share on other sites More sharing options...
gatorman Posted April 12, 2019 Share Posted April 12, 2019 gatorman i do not have the original starter. it came with the d6ra2. so the person i got the bike from changed the original starter and installed the d6ra2 and never rode the bike again because the d6ra2 is not the right starter for the bike and would not start Link to comment Share on other sites More sharing options...
gatorman Posted April 12, 2019 Share Posted April 12, 2019 Gatorman hope the picture posts in my gallery Link to comment Share on other sites More sharing options...
guzzigary Posted April 12, 2019 Share Posted April 12, 2019 Looking at the gallery post methinks gatorman has a California not a V11. 1 Link to comment Share on other sites More sharing options...
docc Posted April 12, 2019 Share Posted April 12, 2019 7 hours ago, guzzigary said: Looking at the gallery post methinks gatorman has a California not a V11. Haha . . . well there is that! Link to comment Share on other sites More sharing options...
gatorman Posted April 12, 2019 Share Posted April 12, 2019 ok i bought a starter for the cal. and it did not work . now what ? when i did a vin decoder it says i have a v11 bass cruiser model year 2001 with the califorina trim. so what model starter do i get??? vin number zgukdbd31m131679 gatorman Link to comment Share on other sites More sharing options...
docc Posted April 12, 2019 Share Posted April 12, 2019 7 minutes ago, gatorman said: Gatorman hope the picture posts in my gallery Yeah, man. Looks like a nice pearl white V11 EV? All my comments were applicable to a 2001 V11 Sport or Rosso Mandello. The EV has a different (5 speed) gearbox and different flywheel from the V11 Sport, so none of my replies are likely going to be helpful. Link to comment Share on other sites More sharing options...
docc Posted April 13, 2019 Share Posted April 13, 2019 Or would the starter I linked you to on MGCycle solve your troubles? Link to comment Share on other sites More sharing options...
