BMWDavid Posted July 30, 2017 Share Posted July 30, 2017 My '02 LeMans idles just a bit low (950) so I thought I would bump it up a bit using the left throttle body, throttle stop screw. Just how tight are these screws? Using a small hex key wrench (2.5mm) I could not get the screw to turn. Mind you I did not lay into it as I did not want to damage the fitment of the hex key to the screw. OK...bike was still warm from a ride so I tried again. While still pretty tight the stop screw did move with a bit of force on the hex key wrench. There is still yellow goop on the screw head and I guess it acts as a thread locking compound. Link to comment Share on other sites More sharing options...
docc Posted July 30, 2017 Share Posted July 30, 2017 Yeah, chip off the yellow goop. It is there to A) detect tampering, or B ) show you where the tamper points are. Idle speed is really best addressed starting with the "Decent Tune-up." Once performed, the idle can be put where ever you like with the left idle stop screw. http://www.v11lemans.com/forums/index.php?showtopic=19610 Link to comment Share on other sites More sharing options...
