coreytrevor Posted September 3, 2017 Author Share Posted September 3, 2017 A datasheet of the earlier mentioned Shindengen would be nice here, the more as a proper power rating should be given in Watt, not in Amps (at 12V). (BTW, why would someone want to screw his Guzzi with such a name? I know a lot of people who would never buy other tires but Pirelli for instance, just because Pirelli sounds right). I don't know if this helps. BTW, the late style V11 regulator is sourced from Shindengen, I happened to see this in my manual today. Riding with a voltmeter connected to the battery, at highway speeds voltage fluctuates between 14.03 to 14.33 volts. This is with the SH775. Link to comment Share on other sites More sharing options...
Kiwi_Roy Posted September 3, 2017 Share Posted September 3, 2017 ... The Shindengen probably uses MOSFET transistors which can be turned from full On to Full Off off mid cycle like the switch mode regulator in a computer ... Roy, what I know is that a MOSFET might theoretically be switchable from On to Off whenever some circuit wants it, differently to Tyristors (SCRs), but practically there's no way to do it. While the RDS(on) (switched fully On) of a MOSFET is rather low, its resistance when switched Off naturally is rather high. Now guess what happens when you try to switch Off a MOSFET under high loads/currents, means rise the resistance from zero to unlimited at maybe 30 Amps. As said above, theoretically this might be possible, practically it usually leads to sudden smell and smoke. Then switching under load is also a bad idea when you have to reach certain EMC goals. These usually are not negotiable. Don't know how it is with computers, vehicle electronics are always build on the lowest possible edge, that means the smallest and cheapest parts available, no reserves to fool with. Ahh, don't tell the manufacturers of Variable speed drives that MOSFETs aren't switchable, they do it all the time at about 20 KHz, before that they used to switch SCRs by reducing the current to zero so they turned off. Having said that I do agree the manufacturers of simple Voltage regulators probably don't spend too much on the hardware. I was an apprentice when the first SCR based variable speed drives came out and I've taken a keen interest in the technology ever since. Before I got into Guzzi the majority of modern motorcycle regulators were shunt type 3 phase units with SCRs to shunt out the coils, I imagine they have been replaced by MOSFETs or something else by now. Link to comment Share on other sites More sharing options...
Guzzi2Go Posted September 8, 2017 Share Posted September 8, 2017 Just looking at the Ta to Io curve above and have to say that this regulator cannot tolerate more than continuous 10A at ambient temperatures it is typically exposed to. Although I did not actually measure, I think I can safely assume that the ambient temperature V11's regulator is exposed to is at least in the range of 60-80°C. 35A seems to be what rectifiers can handle for a short period of time. Although, it is a bit unclear what "No additional heat sink" means. Is it a heatsink in addition to the already existing one, or is the data for the semiconductors only? One way or the other, the thing is not designed to operate at >80°C. Link to comment Share on other sites More sharing options...
luhbo Posted September 8, 2017 Share Posted September 8, 2017 Spoiler! Link to comment Share on other sites More sharing options...
coreytrevor Posted September 8, 2017 Author Share Posted September 8, 2017 Although I did not actually measure, I think I can safely assume that the ambient temperature V11's regulator is exposed to is at least in the range of 60-80°C. I guess I don't understand why the regulator would be exposed to temperatures that high. In the stock position, which I didn't use, it looks to me like the air hitting the regulator would be about the same as ambient outdoor temperature. Link to comment Share on other sites More sharing options...
Guzzi2Go Posted September 8, 2017 Share Posted September 8, 2017 Stock position is behind oil cooler and between cylinder heads. At least on Le Mans.Nice and cozy, I'd say. Anyway, even at 30°C the thing is rated 15A. However, it could well be that the info is simply caca del toro printed on the box in order to make the product look, er... "professional" (lacking better word). Link to comment Share on other sites More sharing options...
coreytrevor Posted September 8, 2017 Author Share Posted September 8, 2017 My stock regulator was under the oil cooler, not so much behind. And even though the heads and exhaust are not far away, it seems once the bike is moving more than a few mph the airflow will sweep all the heat to the rear. I guess we can agree to disagree. Link to comment Share on other sites More sharing options...
coreytrevor Posted September 8, 2017 Author Share Posted September 8, 2017 Also, I will let everyone know as soon as it burns up! It's been doing ok so far here in 100 degree weather. Link to comment Share on other sites More sharing options...
swooshdave Posted September 29, 2018 Share Posted September 29, 2018 Corey, any updates? I’d really like to try one of these. Link to comment Share on other sites More sharing options...
Tomchri Posted October 14, 2018 Share Posted October 14, 2018 Corey, or anybody. The season is over up here, and the Corsa took the last trip home In the van. Lost tach and a few miles later died. Charged the battery, and started right up, all well, just not charging. Seems to me SH775rr regulator would be a better choice ? Anybody with experience In this matter ? More reading,,, and IPA time. Cheers tom. Link to comment Share on other sites More sharing options...
docc Posted October 14, 2018 Share Posted October 14, 2018 Corey, or anybody. The season is over up here, and the Corsa took the last trip home In the van. Lost tach and a few miles later died. Charged the battery, and started right up, all well, just not charging. Seems to me SH775rr regulator would be a better choice ? Anybody with experience In this matter ? More reading,,, and IPA time. Cheers tom. No charging + no tachometer could = 2nd ("Headlight") Relay. You have headlights, brake light? Link to comment Share on other sites More sharing options...
Tomchri Posted October 14, 2018 Share Posted October 14, 2018 Headlight working,,,, didn't check rear. Regulator cold, heat from stator when I started her up after charging the battery. 55400km now, 34000m, its time for an upgrade isn't it, Cheers tom Link to comment Share on other sites More sharing options...
docc Posted October 14, 2018 Share Posted October 14, 2018 What does the voltmeter say? Link to comment Share on other sites More sharing options...
Tomchri Posted October 14, 2018 Share Posted October 14, 2018 ….This is not a cry for help. Superbike in Argentina right now,,,,, but into the garage #2 Omron out, all the Connectors from Down under,, all metal same hight. This is just a minor detail,, I have plenty of time to sort it out. Just a little curious about a better regulator. And again she sure looks good on the w bench, positive yes, why not. If it was in may,,, different story. Meaning not ordering parts tomorrow, will follow this tread. Cheers tom. Curious again, Docc, same cylinders With Your mileage ? Link to comment Share on other sites More sharing options...
Tomchri Posted October 14, 2018 Share Posted October 14, 2018 After the bike stalled,, took about 2hours to get her home, battery had recoverd a little,, actually trying to start,( noticed headlamp on the garage door ) inside garage checking V, 11.73. chheers tom. Link to comment Share on other sites More sharing options...
