swooshdave 735 Posted November 7, 2017 Report Share Posted November 7, 2017 How about a selection of broken spring pictures, surely there must be plenty of examples. Are they all breaking in the same place? Quote Link to post Share on other sites
Chuck 1,530 Posted November 7, 2017 Report Share Posted November 7, 2017 How about a selection of broken spring pictures, surely there must be plenty of examples. Are they all breaking in the same place? In this thread alone, there are pictures of the spring breaking in different places. That hints at a metallurgy/heat treat problem to me. A simple spring like this should be able to be wound from music wire, and be bullet proof, I would think. 2 Quote Link to post Share on other sites
Scud 1,329 Posted November 7, 2017 Author Report Share Posted November 7, 2017 ... If you look carefully in the above picture, you can see where the two springs almost meet. This is with the lever in the downshifting position. But that's not the end position, is it? In the end positions the bump resp. the step would have contact with the small excentric pin, the lock pin as you could call it. There is some travel remaining to end position. It was hard to hold the levers in place and take the photo at the same time. The discovery here, at least for me, is that the little right-angle part of the spring cannot be larger - because it would interfere with another spring. Quote Link to post Share on other sites
Scud 1,329 Posted November 7, 2017 Author Report Share Posted November 7, 2017 I've seen breaks in two positions - personally and in reviewing other threads. I think the most common is in the coil (as in my picture on the first page). Next is that the small straight piece breaks off at the 90-degree bend. That's what Czakky described and what I experienced very shortly after installing it on my Scura. The break on the coil was on my LeMans, which has the correct size boss for the coil to go around. Anyway, I just heard back from the spring place. They can make 50 springs at $6.00 and 100 @ $4.00 each. I just talked with the representative. He said they would make it from piano wire. Apparently, there is another, slightly cheaper material that is commonly used, but it is weaker than piano wire. I'm going to mail him a broken spring and a new one. He thinks he may be able to use a slightly thicker wire, but has to have the sample in hand before promising anything. I don't want to get over-optimistic, but I think I smell a solution. 2 Quote Link to post Share on other sites
luhbo 236 Posted November 7, 2017 Report Share Posted November 7, 2017 A thicker wire might break easier. I think that the thickness is limited by the travel the legs make, so I'd try a thinner one. Quote Link to post Share on other sites
Chuck 1,530 Posted November 7, 2017 Report Share Posted November 7, 2017 Piano wire would be good. I think I smell something,too.. oh, it's just a smellfie. I'd go with the spring manufacturer's recommendation. Piano wire, music wire.. same same. https://www.mcmaster.com/#piano-wire/=1a5kz24 1 Quote Link to post Share on other sites
Scud 1,329 Posted November 7, 2017 Author Report Share Posted November 7, 2017 When I mentioned the possibility of using a thicker wire, he said that would reduce how far the spring could bend (and therefore would break easier). I just ASS-u-med thicker would be better, but maybe thinner would be more durable. He also said that a weak spot is created anytime a tool holds the wire and a bend is applied. That's why we are seeing breaks most frequently at 2 specific locations. But maybe just using the highest quality raw material (piano wire) will solve it. It's easy to imagine a strapped-for-cash Moto Guzzi production manager choosing to downgrade the spring material to save a Euro a unit. "Hey we can save €10,000 this year by using material X instead of piano wire..." While I am getting a free "Spring 101" class, he's pretty clear that he doesn't give advice or make recommendations... the company makes springs to specifications, not to applications. The customer does their own engineering. Quote Link to post Share on other sites
swooshdave 735 Posted November 7, 2017 Report Share Posted November 7, 2017 How about a selection of broken spring pictures, surely there must be plenty of examples. Are they all breaking in the same place? In this thread alone, there are pictures of the spring breaking in different places. That hints at a metallurgy/heat treat problem to me. A simple spring like this should be able to be wound from music wire, and be bullet proof, I would think. There is actually only one picture of a broken spring in this thread that I can find. It's good to gather the data on where the spring is breaking (if more than one location) before solutioning. Quote Link to post Share on other sites
swooshdave 735 Posted November 7, 2017 Report Share Posted November 7, 2017 While I am getting a free "Spring 101" class, he's pretty clear that he doesn't give advice or make recommendations... the company makes springs to specifications, not to applications. The customer does their own engineering. Either there is a quality issue, a design issue or both. For a 15+ year old motorcycle sometimes it's easier to re-engineer (which typically means over-engineering) a solution. Quote Link to post Share on other sites
docc 3,762 Posted November 7, 2017 Report Share Posted November 7, 2017 Mine broke within s few mm of scud's shown on page one. 1 Quote Link to post Share on other sites
luhbo 236 Posted November 7, 2017 Report Share Posted November 7, 2017 Spring Is Sprung - another nice old times read from 2004 Quote Link to post Share on other sites
Chuck 1,530 Posted November 7, 2017 Report Share Posted November 7, 2017 This might be instructive.. https://www.acxesspring.com/torsion-spring-calculator-instructions.html 1 Quote Link to post Share on other sites
swooshdave 735 Posted November 7, 2017 Report Share Posted November 7, 2017 This might be instructive.. https://www.acxesspring.com/torsion-spring-calculator-instructions.html That helps but you also need to know what material and tempering you want. Quote Link to post Share on other sites
Chuck 1,530 Posted November 7, 2017 Report Share Posted November 7, 2017 This might be instructive.. https://www.acxesspring.com/torsion-spring-calculator-instructions.html That helps but you also need to know what material and tempering you want. One of the things you can calculate on a torsion spring is music wire.. that's what Scud is looking at. Thought it might give an optimum dia. etc. Quote Link to post Share on other sites
swooshdave 735 Posted November 7, 2017 Report Share Posted November 7, 2017 This might be instructive.. https://www.acxesspring.com/torsion-spring-calculator-instructions.html That helps but you also need to know what material and tempering you want. One of the things you can calculate on a torsion spring is music wire.. that's what Scud is looking at. Thought it might give an optimum dia. etc. If that’s even the right material to use. Sent from my iPhone using Tapatalk Quote Link to post Share on other sites
Join the conversation
