Scud
Voltage Reg and Charging Problem?
I say "[battery]" because I could not keep stacking terminals on the battery itself, and built connector blocks for both the positive and negative battery terminals.  Instead of fusing the headlight positive, I'm using an auto-reset 10 amp ATC circuit breaker.
Share this post
Link to post
The original Ducati Energia is a series regulator, it opens the circuit instead. IMHO these are a good regulator let down by the flaky Voltage reference from the headlight circuit.
I think I misread this and assumed the Ducati Energia was the stock regulator for the V11 Sport. It is not, correct?
Share this post
Link to post
I wired my headlight circuit seperately via a pair of mini relays so now the regulator reference voltage stays constant and the handlebar switches dont carry the headlight current.
Is there a diagram of where best to put the relay? I'm searching now through the archives and have found some. Do you know which one you used?
Like docc I mounted my mini relays in the headlight shell.
Share this post
Link to post
The Voltage reference is permanently connected to the battery making it more reliable, it only draws about 0.3 milliamps but it will flatten the battery over time.
Yep, it takes about 3-4 weeks for my newly installed ESR515 to drain the battery.  DAMHIK.
Share this post
Link to post
But if you put a relay in that circuit it won't, right?
Share this post
Link to post
On the ESR515, there isn't a separate wire for sensing the voltage, so no where to run a relay switched reference.  :bbblll:
Share this post
Link to post
Couldn't you put a relay in the power line going from the regulator to the battery?
Share this post
Link to post
Kinda defeats the purpose of having that nice hard wire connection between the regulator and battery.  But yes you could.
Share this post
Link to post
The drop from the relay and the regulator pushes juice to the battery might be manageable enough. Kiwi Roy should be along at some point to correct me.
Share this post
Link to post
Which of these wires is the voltage reference one?
Share this post
Link to post
Hm . . . tough question. The black voltage reference is at another connector on the left side of the frame . . .
Share this post
Link to post
Charging & rectifier
03 Rosso Corsa.
My fault was visible and smellable.
Stator fine, usually 2 bullet connectors not to bad, other connector, see pictures .
Just want the best rectifier available?
Shindengen 847? Or ?
And a tiny Christmas wish. Someone decided to make a simple upgraded wiring for the V11 ( K.R. )
IPA TIME
Cheers tom d98c20ebaac2f168e93f8f062e841129.jpgecef94f20c15252fb641140bd439f183.jpg665bb498ed569b77f29e4694447405c6.jpgb1d3accdd0e3690fac8c5deac44d79d6.jpgdcace0fb7a0514fb211c6741bdc574da.jpg1ecad4d1c1cb9b7602e1d818c19c9b50.jpg0514c8f5e93c36054b8ff6afd4bedd99.jpg
Sent fra min SM-G903F via Tapatalk
Share this post
Link to post
The first thing you have to worry about is fake regulators. So just be careful on eBay.
If you're in Norway I guess you're use to having a hard time getting parts?
I'm currently leaning towards a Electosport ESR550 which is the MOSFET style although you'd have to put new connectors in (looking at the pictures I think you're already in line for that) and you'll lose your charging light on the dash (unless you hack something) or put a voltmeter on the bike.
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
