Dadparent Posted August 16, 2018 Share Posted August 16, 2018 I have a strange problem. When the bike comes to 200 kmph the needle of the speedometer collapse to zero. And from that moment the meter fails to work. Until I stop and from that moment everything is ok until the 200 Kmph. Anyone any ideas ? Verzonden vanaf mijn iPad met Tapatalk Pro 1 Link to comment Share on other sites More sharing options...
shiloh Posted August 16, 2018 Share Posted August 16, 2018 It's telling you not to drive that fast? Link to comment Share on other sites More sharing options...
docc Posted August 16, 2018 Share Posted August 16, 2018 This is a V65? What year? Link to comment Share on other sites More sharing options...
Dadparent Posted August 17, 2018 Author Share Posted August 17, 2018 Hello , no it’s a V11 Lemans 2002. I replaced the clutch,so the speedo was taken out of the gearbox and replaced. But I replaced it and nothing changed. Verzonden vanaf mijn iPad met Tapatalk Pro Link to comment Share on other sites More sharing options...
Dadparent Posted August 17, 2018 Author Share Posted August 17, 2018 Sorry for my English. After the first remounting I did it again, but the problem stayed. Verzonden vanaf mijn iPad met Tapatalk Pro Link to comment Share on other sites More sharing options...
stewgnu Posted August 17, 2018 Share Posted August 17, 2018 Ah yes, mine did this a couple of years back, you need to take it up to 300kph and the system resets itself. 2 Link to comment Share on other sites More sharing options...
docc Posted August 17, 2018 Share Posted August 17, 2018 Ah yes, mine did this a couple of years back, you need to take it up to 300kph and the system resets itself. 1 Link to comment Share on other sites More sharing options...
footgoose Posted August 18, 2018 Share Posted August 18, 2018 Dadparent. Our Veglia's are not of high quality construction. Seem's like most fail at some point, in different ways. Usually erratic indicator movement and then just stops function. Many owners upgrade to aftermarket gauges when this happens. Speedhut is a popular well made unit, with much information on this forum. I have not heard of the problem you are having, though someone here may have. You may be the owner that 'gets' to figure it out. Let us know the outcome. If mine started doing something like that, I'd take it apart to see what I could see, and if I could repair it. Then I'd buy the Speedhut set. 1 Link to comment Share on other sites More sharing options...
Tomchri Posted August 18, 2018 Share Posted August 18, 2018 Sorry I missed the point here, you said after 200 km what happened, If it's sort of working under 200km, your OK. Time for another IPA. Cheers tom Link to comment Share on other sites More sharing options...
docc Posted August 18, 2018 Share Posted August 18, 2018 I would be suspicious of the angle drive at the gearbox, driving the cable to the white face Veglia. They can come apart a couple different ways. Make sure the metal blanking disc is secured and the unit is pressed well into it's mounting couple. Also, that the angle drive is tightened well to the gearbox and the short gearbox drive shaft is seated correctly. Link to comment Share on other sites More sharing options...
Lucky Phil Posted August 18, 2018 Share Posted August 18, 2018 Sorry I missed the point here, you said after 200 km what happened, If it's sort of working under 200km, your OK. Time for another IPA. Cheers tom After 200kph you switch over to Mach Number for speed:) Whats the mach speed indicator showing? Ciao Link to comment Share on other sites More sharing options...
Dadparent Posted August 18, 2018 Author Share Posted August 18, 2018 Hey guys, Thank you all for the response. I figure it out and I'm afraid that will take some time. But when I have a solution I promise to give the solution. Why Will it take so long? You US guys made me clear that we Europeans are irresponsible. So that will take some time for visiting a psychologist. But I'm afraid that he can't cure, as for many Europeans. But to be honest I drive it not every day and this was for a try out of my just bought V11. Verstuurd vanaf mijn SM-G950F met Tapatalk 2 Link to comment Share on other sites More sharing options...
