r3datom9 Posted April 29, 2019 Share Posted April 29, 2019 I have the preselector removed from my bike and ready to ship. It is in perfect working order. It is currrently on ebay. https://www.ebay.com/itm/163655856298 1 1 Link to comment Share on other sites More sharing options...
ready180a Posted April 29, 2019 Author Share Posted April 29, 2019 10 hours ago, ready180a said: Thanks for that, I have measured the original ones that came out and they tally up with what yours are . I will have another check tonight in side the gear box and post back . Regards Tony After having a fresh look and measure tonight the newly fitted drive dogs are 22mm overall and 12.6mm on the minor thickness . When you measured yours did you check your old parts of the current ones in your gear box ? . Trying to get to the bottom of the problem isn’t so easy . Thanks for your help tony Link to comment Share on other sites More sharing options...
Lucky Phil Posted April 29, 2019 Share Posted April 29, 2019 2 hours ago, ready180a said: After having a fresh look and measure tonight the newly fitted drive dogs are 22mm overall and 12.6mm on the minor thickness . When you measured yours did you check your old parts of the current ones in your gear box ? . Trying to get to the bottom of the problem isn’t so easy . Thanks for your help tony Mine is a 2002 gearbox so it wasn't affected by the recall. From a little research it seems the original problem with the sleeves was a hardening issue not a dimensional one but that's not definitive and I haven't any pre mod sleeves to look at. The only other transmission that uses the V11 six speed is the MGS-01 and I dont know what the sleeve looks like in those only that the part number is different. I still think it would be preferable to strip the trans and install the correct sleeves rather than machine the selector wheels though for several reasons. Ciao Link to comment Share on other sites More sharing options...
ready180a Posted April 29, 2019 Author Share Posted April 29, 2019 5 minutes ago, Lucky Phil said: Mine is a 2002 gearbox so it wasn't affected by the recall. From a little research it seems the original problem with the sleeves was a hardening issue not a dimensional one but that's not definitive and I haven't any pre mod sleeves to look at. The only other transmission that uses the V11 six speed is the MGS-01 and I dont know what the sleeve looks like in those only that the part number is different. I still think it would be preferable to strip the trans and install the correct sleeves rather than machine the selector wheels though for several reasons. Ciao Hi , thank you for confirming the age of your gear box and taking the time to check your gearbox . It has been very helpful and you have confirmed that the dogs in mine are not correct , and the gear box will have to come out and go back to be stripped back down to replace them . Its frustrating as the wether has picked up hear and I had got it ready for an mot, and I guess I’m looking at 2 months at least before this is sorted !! I will keep you all updated with progress. Thanks again , kind regards Tony 1 Link to comment Share on other sites More sharing options...
Lucky Phil Posted April 29, 2019 Share Posted April 29, 2019 3 minutes ago, ready180a said: Hi , thank you for confirming the age of your gear box and taking the time to check your gearbox . It has been very helpful and you have confirmed that the dogs in mine are not correct , and the gear box will have to come out and go back to be stripped back down to replace them . Its frustrating as the wether has picked up hear and I had got it ready for an mot, and I guess I’m looking at 2 months at least before this is sorted !! I will keep you all updated with progress. Thanks again , kind regards Tony Bummer. Be interesting to see what those sleeves are from. Ciao Link to comment Share on other sites More sharing options...
ready180a Posted May 1, 2019 Author Share Posted May 1, 2019 On 4/29/2019 at 10:53 PM, Lucky Phil said: Bummer. Be interesting to see what those sleeves are from. Ciao I will keep you updated with progress thank you all for your help . Kind regards Tony Link to comment Share on other sites More sharing options...
ready180a Posted May 30, 2019 Author Share Posted May 30, 2019 Just a quick update the gear box is now sorted after sourcing a new old stock recall kit from America. The ones fitted from Moto guzzi where 2 mm to thick not slowing the gears to be Selected a massive thank you for everybody’s input on trying to find the problem . The bikes all back together and hoping to get an mot . Regards Tony 2 Link to comment Share on other sites More sharing options...
Lucky Phil Posted May 31, 2019 Share Posted May 31, 2019 7 hours ago, ready180a said: Just a quick update the gear box is now sorted after sourcing a new old stock recall kit from America. The ones fitted from Moto guzzi where 2 mm to thick not slowing the gears to be Selected a massive thank you for everybody’s input on trying to find the problem . The bikes all back together and hoping to get an mot . Regards Tony How the hell does that happen? I mean 2mm!!!! Ciao Link to comment Share on other sites More sharing options...
ready180a Posted May 31, 2019 Author Share Posted May 31, 2019 6 hours ago, Lucky Phil said: How the hell does that happen? I mean 2mm!!!! Ciao no idea the parts came straight from guzzi and where made to order , the mechanic is going to Itali this weak and has taken the parts to try and get to the bottom of it !!! i will keep you updated with the out come . 1 Link to comment Share on other sites More sharing options...
ready180a Posted May 31, 2019 Author Share Posted May 31, 2019 Link to comment Share on other sites More sharing options...
