Looking at the stock fuel map for a 2001 V11, it has some odd peaks and troughs in:
Anyone know why this is?
For example at 2000 rpm tps 48, is a peak of 193, which drops off at higher and lower rpms and higher and lower tps.
There is also a low fuelling trough at 4000 rpm at wider TPS values.
Hi,
I still get frequent requests for the latest V11 BIN.
During the last 2 years my activities have moved on to other bikes, Guzzi Jackal, Norge 1200 2V, Aprilia Mana GT and Aprilia RST 1000 Futurua. So I didn't have the time and inclination to do further work on the V11 BIN. This will likely change, as I plan do some work on my V11 (suspension, cylinder head porting, valve & valve guides, valve timing, ...) during this winter.
Also the experience gained since scrapping the u
