marktheaxeman Posted June 4, 2019 Share Posted June 4, 2019 Hi there. Has anyone got the standard foot rests, rear brake lever, gear lever and linkages that they want to sell? At the moment I have rear sets which are a bit high for me and would like to put it back to the standard set up. Ive has a look at doing it with new parts but some of the required bits don’t seem to be available and the prices are ridiculous!! Also if anyone wants to swap their standard set up for my custom rear sets then I’d be up for that im in Bath Somerset Uk thanks. Link to comment Share on other sites More sharing options...
Admin Jaap Posted June 4, 2019 Share Posted June 4, 2019 Try rebootguzzispares.com Link to comment Share on other sites More sharing options...
footgoose Posted June 4, 2019 Share Posted June 4, 2019 Ducati Monster - late '90s foot pegs are the same, but with a nice rubber covering. Just a thought. Link to comment Share on other sites More sharing options...
docc Posted June 4, 2019 Share Posted June 4, 2019 (Be aware that the early '99-'01 gearshift lever is different from the LongFrame '02+ V11. The early brake lever is ~5/8" shorter, but will still work on the later frames.) Link to comment Share on other sites More sharing options...
Scud Posted June 5, 2019 Share Posted June 5, 2019 I might have all that, but will need to check to be sure. I'll be home Saturday. If I do, it's all powdercoated black. Link to comment Share on other sites More sharing options...
marktheaxeman Posted June 5, 2019 Author Share Posted June 5, 2019 7 hours ago, Scud said: I might have all that, but will need to check to be sure. I'll be home Saturday. If I do, it's all powdercoated black. Scud that would be great if you have it all. I can remove the powder coating no problem as my bike is all ally. I would need the long bolt as well which holds the gear lever in place and the small arm which fits on the gearbox spline. Let me know how much you have and what you want for it. I'll cover the postage costs. Cheers Mark. Link to comment Share on other sites More sharing options...
marktheaxeman Posted June 5, 2019 Author Share Posted June 5, 2019 10 hours ago, docc said: (Be aware that the early '99-'01 gearshift lever is different from the LongFrame '02+ V11. The early brake lever is ~5/8" shorter, but will still work on the later frames.) Docc will the later brake and gear shift work on the red short frame - which my bike is?? Cheers, Link to comment Share on other sites More sharing options...
marktheaxeman Posted June 9, 2019 Author Share Posted June 9, 2019 On 6/5/2019 at 2:40 AM, Scud said: I might have all that, but will need to check to be sure. I'll be home Saturday. If I do, it's all powdercoated black. Hi Scud - any luck with finding the levers and foot rests etc? cheers Mark. Link to comment Share on other sites More sharing options...
swooshdave Posted June 9, 2019 Share Posted June 9, 2019 If you want pegs that are nearly identical to the stock ones try these. They fit a red frame perfectly. https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F223399494278 Link to comment Share on other sites More sharing options...
marktheaxeman Posted June 10, 2019 Author Share Posted June 10, 2019 Thanks swooshdave - cheap as chips too!! 1 Link to comment Share on other sites More sharing options...
