Bill Hagan
Dead Norge at Side of Road
John Wells recently sold his early 2007 Norge (sister VIN to mine) to friend, Ray.
We are all at western N.Y. rally in Westfield, N.Y.
On short ride this a.m., Ray’s Norge -- 11K miles; well maintained --- “died” underway.
Checked all fuses and relays.  All appear good.
Ruled out (preliminarily, at least) sidestand interlock.
Starter cranks; no start.
John — who is on the scene and whom I cc — and others there believe related to internal fuel pump as I understand they can see fuel “swirling,” which they recall as filter failure?
Given unavailability of OEM, might any of you know of clone that would work?
Other ideas/suggestions?
Bill
404.8ZERO8.8486
Share this post
Link to post
Check for spark. You can get a bit of swirling around because the pressure regulator is inside the tank.
Are the plugs dry? If the plugs are dry and no spark, it could be the timing phase sensor.
Share this post
Link to post
Sounds like hose blown off filter Bill. See my Ghetto post.
Share this post
Link to post
Thanks to all.
Seems hose was OK.
Tho perhaps removing the clamps on the the OEM filter MAY have done some damage. :luigi:
Be that as it may, the culprit this time was the filter itself.
The plastic half of the OEM was so swollen -- presumably from cursed ethanol -- that it split at the seam with its metal mate.  :angry2:
Guzzisteve called in the NAPA part #[GOLD 3032] and all was well.  :notworthy:
I'll post some pix of this and more when I get back home on Monday.
Bill
Share this post
Link to post
Always a good feeling when the gremlins are defeated, even vicariously.
  • Haha 1
Share this post
Link to post
As I posted this Paul Harvey on ADVRider, I should repeat it here:
I never miss a chance to knock or ping (pun intended; sorry) ethanol, but fairness requires me to back away from my view that ethanol is the sole culprit in the swelling plastic fuel filters.
I have now had two Guzzisti -- in England and Oz -- report that they have had the same thing happen to theirs without ethanol playing any role whatever.
Both questioned Mahle (the filter maker) and were told that "it was designed for use with diesel fuel and on no account should it be immersed on petrol/gasoline."
If so, mighty hard to figure out why Guzzi continues to use the things. :angry:
Bill
P.S. I still detest ethanol; corn is for bourbon.  :drink:
Share this post
Link to post
Oh, we know why. :rasta:
  • Haha 1
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
