Mikko
Recommendation for Lambda Sensor
Was thinking of buying a MyECU and Cliff said the innovate sensors he used to recommend failed. What would be a good, reliable sensor to use? Heated preferred. Thanks!
Share this post
Link to post
I use a DIY kit from WBO2 with great success. Was looking at 14point7 because of the size of it and it's relatively nice price.
MyEcu is a good idea. Have it running since 2005, nearly 200.000 km, lots of fun.
Share this post
Link to post
I’m trying to decide if spending $500 for a new ECM is worth it. The other option is the AMM-P1  ignition and carburetors. At least with carbs you can pull all the F.I. stuff out, lose the weight and complexity and be able to reliably start and ride even with a dead battery.
I mentioned in another post that if you went that route and utilized a M-Unit, you would eliminate about 80% or more of all the Luigi grade wiring on the bike. Plus no more relays/fuses/sensors going bad.
hmmm....
Share this post
Link to post
The My15M should cost 500USD nowadays?
Share this post
Link to post
something like that with shipping..then however much for a sensor.
Share this post
Link to post
I don't think it can give you a 500usd satisfaction.
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
