Mikko
Petcock mounting size
I’d like to replace both with Pingal’s. Try to find smaller diameter or at least some that would make pulling the tank off easier. Anyone know what the size is for the adapter that bolts into the bottom of the tank?
thank you!
Share this post
Link to post
I can check that in few hours when I can get to my pile. The device on the right is not a petcock, but the actual pressure regulator.
Share this post
Link to post
Really? What a weird and wonderful place to put that... hmmm.. I didn’t know, I was on the “damn it I poked my finger side”...
Share this post
Link to post
Is your petcock manual (knob) or are there wires coming from it?
Share this post
Link to post
The Scura has the external fuel pump and filter?
Share this post
Link to post
So, yeah, 2002 V11 (including the Scura) should all have "chin pad tanks" with external fuel pump and filter with the regulator on the bottom right of the tank. Not sure when Guzzi gave up on the early (unreliable) electric petcocks and went back to the manual version.
And, nuts, I dug out the "electric cock" I removed from my Sport and it does not reveal what is tapped into the tank itself, only the female threads that attach onto the tank tap.  Not sure that would help you at all, Mikko?
Share this post
Link to post
Looking at the parts manual for 2002, looks like it might be manual. No wires shown on the drawing, part number is GU29105460
The electric petcock part number is GU01105330
If you measure the inside diameter of the female threads (in mm naturally) and add two, that should give the size of the male part, no?
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
