gstallons Posted August 8, 2019 Share Posted August 8, 2019 I see where some BMW rider and his ambulance chaser has filed ( in NJ ) a class action lawsuit against BMW for all things , faulty gearshift indicators . Their feelings are hurt because the rider cannot tell what gear they are in . Somehow , I can see that . Link to comment
Chuck Posted August 8, 2019 Share Posted August 8, 2019 A mechanic friend says it means Bitch Moan Whine.. 1 Link to comment
GuzziMoto Posted August 9, 2019 Share Posted August 9, 2019 14 hours ago, Chuck said: A mechanic friend says it means Bitch Moan Whine.. That is good. I like that. I saw a blurb about the recall, did not read past the headline. If it really is just the gear indicator that really is some weak cr@p there. I can't imagine needing one in the first place, but to not be able to properly and safely ride because of one not working right? Just F'ing ignore it and ride. I had a Honda CTX for a couple of years. It had one, in part because it had their DCT trans. It was about as useful as those old "economy" gauges they would put on big American V8's in the 70's (that were nothing more than a vacuum gauge). If you wanted to have power you had to accept that your "economy / vacuum was going to go down. All the gauge did was let you see it. 1 Link to comment
guzzler Posted August 10, 2019 Share Posted August 10, 2019 Ha ha Bavarian Money Waster It is said that fools and their money are easily parted ! Cheers Guzzler Link to comment
Lucky Phil Posted September 18, 2019 Share Posted September 18, 2019 Ive owned a couple of K100's in the past and the gear indicator was one of those things that you don't really need but its nice to have. I generally used it to check I was in top gear. I still toe the lever sometimes to check I'm in 6th when my brain is in neutral Ciao Link to comment
GuzziMoto Posted September 18, 2019 Share Posted September 18, 2019 Yeah. I occasionally toe the shifter to make sure I am in top gear, and I also flip the turn signal switch off as a habit. Having a gear indicator would be nice. But if it didn't work right I don't see how it could be a safety issue. Link to comment
