Mikko
Check & Replace those intake boots!
I can’t remember exactly where on this site, but I think it was a post by Docc about intake boots. I ordered a pair from MG Cycle and a new oil pressure switch/boot.
Got to replacing the boots today and yup... one was torn and the other one cracked. Good idea to replace them!
6701FE74-F9C8-4FC6-BF79-767034FC5925_zps
C10A447D-47F0-4D26-8B3C-3D1B62052079_zps
Ain’t showing up to the spine raid like that! This is more like it!
B0DEF915-7AE6-4390-A188-30E6A4AE7B6F_zps
index screw heads for optimal air flow....
08FDF0E7-701E-44D0-9321-1CCF38278543_zps
Share this post
Link to post
Yeah, that's a pretty common failure with injected Guzzis.
Share this post
Link to post
I've been struggling with unstable idle, popping and misfiring at low throttle openings, and lean-condition issues since my last (boarched-up) tune-up. Changed a bad TPS, re-sycnch'd,  and so forth. Last night on the lift using that most important of Special Tools, the Fine-Toothed Comb, I found evidence of an un-metered air leak at the intake taps. I very carefully snugged it up (since I can't remember which one has the Heli-Coil) . . .
Today, in very high ambient temperatures, I could not believe the improved behavior! Sweeeeeet! Came home and very slightly tweaked the synch with Hg sticks and both air screws same at 1 full turn. Fresh rubber caps on the taps. Idle back stable.
So great! I'm amazed how that loose vac tap was so significant. :race:
Share this post
Link to post
Mikko made me look! :D
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
