andy york
stator
Hi again
could some refresh my memory as to the ac voltage on the 2 yellow wires from the stator.
trying to determine why my charge light is on
thanks
Andy
Share this post
Link to post
8 minutes ago, andy york said:
Hi again
thanks
Andy
WMV11_Alternator&Reg.pdf
Share this post
Link to post
What is the voltage at the battery key off? At idle ? At a couple thousand RPM?
Share this post
Link to post
Seems to me that is should be around 40V AC at around 4K rpm.
Share this post
Link to post
Yep,  Workshop Manual says 15 volts AC at 1000 rpm,  40vAC @ 4000, 80 vAC @ 6000.
Share this post
Link to post
On 8/18/2019 at 3:49 PM, andy york said:
Hi again
thanks
Andy
Maybe we can get together , My light will NOT come on ?
Share this post
Link to post
The regulator is the common failure. My light only comes on depending on the phases of the moon.
Share this post
Link to post
LOL.    I wasn't aware that mine worked.In a previous regulator install, the directions said the charge light would be in operative.
beats me....but its on now.  Need to find a Shinnding reg or whatever its called. Like to try something different.
Share this post
Link to post
beats me....but its on now.  Need to find a Shinn  ding reg or whatever its called. Like to try something different.
Only done about 4000miles with my  upgrades,    Shindengen 847 on 2 bikes.     My stator and regulator seems to have a healty temp, compared to before.   And I run without the 30amp fuse    :D.
Cheers tom.
Share this post
Link to post
3 hours ago, luhbo said:
Cutting out this 30A fuse is dangerous.
Now you made me wondering .  And I just put in a fuse.    It was just a test to see if everything was working without the fuse,   and it was  ?
 Cheers tom.
Share this post
Link to post
With the fuse open the regulator won't work, means won't charge. With the fuse solidly bridged (what I understand under "running it without a fuse") you go a rather high risk of fire in whatever form. Because then you have your mighty Odyssey directly connected either to the regulator or, in case of a shorted cable, directly to the frame or the engine etc.
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
