ronkom
'03 V11 Sport paint
This is copied from my response to another thread, thought it might be missed.
ronkom
"As I'm going to hang on to the bike, next problem is paint. Bike has maroon tank, dark grey metallic front fender & buddy seat cover, all of which are in very good shape. The problem is a kind of medium grey on the sidecovers and tail piece. A PO apparently tried some sort of coating on the medium grey paint, ruining the finish. I've tried everything I can think of to recover a finish that looks decent...no joy.  So, the only option is repaint. Anyone who's had painting done recently knows how ludicrously expensive the paint alone is (two, sometimes 3 component finishes) . And I only need a small amount for two sidecovers & the tail piece . A minimum order of paint would leave me w/nearly full cans to go on the shelf & dry out over time.  I don't necessarily need a perfect match for the stock color. My thought is to visit body shops around town & see if anyone is painting a vehicle w/a color that would work & ask if they'd  "piggy back." my bike pieces.  I have no idea how that request might will fly. Suggestions? Ideas?"
PO: Was the grey paint originally a flat or semi-flat finish?
Share this post
Link to post
The grey isnt so bad. Do you have a pic? I know the paint scheme and the colors.
What may of happened is the prior owner could of polished out the flat to polished? If that's the case you can try a flat clearcoat or an eggshell clearcoat which can be done cheaper than a color match and respray.
Obtaining paint codes for these Guzzis can be tough to impossible. There is a place that still makes touchup but not sure if they still do it.
Share this post
Link to post
I don’t know if this is useful, but this site,  https://www.reranch.com/  sells nitrocellulose lacquer in aerosol cans. These paints are sold for refinishing guitars, but I think they may be very close to old style automotive paint. The colors offered match the colors of vintage Fender, et al, guitars, which are often the same colors used by car makers in the 50’s.
I used their products to refinish a Stratocaster body, and once the wood was prepped it was a series of many coats of lacquer and wet sanding, followed by coats of clear coat and wet sanding. It took some time but was economical and the end result was very good. If they have a color that works it might be an economical fix.
Share this post
Link to post
I agree with Rox Lemans, might be worth taking the pieces into a decent paint shop to see if they can salvage the original paint and refinish with some type of clear coat, if it worked, best and cheapest solution?.
I have heard of decent paint suppliers making up custom, quality spray bombs, but I don't think anything like that is going to come cheap either, and from experience, painting is a learned art.
I not only hoard motorcycles but info as well,lol.
I snagged this enclosed document that Mike from MPH had posted somewhere with valid paint codes for some of the modern guzzis, I don't see any V11s on the list, but I did notice a few greys that MG has used in the past, might be worthwhile comparing against yours for a possible match with greys on other models.
Ps, due size limitations I can't post the doc, if you want it, pm me an email add, and I can get it to you. While searching for Mike's original post I found a few posts that may help you out, I copied the link over for one that seems to have a lot of links and info, fwiw.
Good luck
Kelly
Share this post
Link to post
Yes they did use several greys. Look at this pic of my '03 Rosso Corsa (rip) and see if your grey is close. If it is I'll get a better pic to see if it's the same. If it is and it would be usefull, I could send/lend you a part to get analyzed for duplication.
The pic can be blown up, and the greys on the bike are all the same, and are high gloss.  Only the red has been repainted
Share this post
Link to post
Actually, it would be helpful to know which paint scheme you have. From this http://www.thisoldtractor.com/moto_guzzi_more_topics_photos_-_moto_guzzi_v11_sport_naked_-2003-.html
it looks like they used 2 (maybe) different greys for the 03 Sport. All look to be flat sheen.
Share this post
Link to post
Yes I'm thinking the same..... possibly three different greys.
The other is the flat super soft grey used on the RM.
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
