milar Posted November 8, 2019 Share Posted November 8, 2019 After a trip to the White Mtns. last month I decided to lower my V11 LeMans foot pegs for a bit more comfort. My mechanic and I found a way to lower the stock foot pegs using existing mounting holes. It lowers them about an inch. I can gain another inch if I switch to Buell pegs. But for now, these are significantly more comfortable. Attached are before and after pics of both sides. The left side is a simple swap. The right side needs a different bolt. (Still lovin' the bike Tim! It's my go to GT bike.) Mike 1 1 Link to comment Share on other sites More sharing options...
LowRyter Posted November 8, 2019 Share Posted November 8, 2019 As Gomer would say, "well gawleeee". So the pegs are tight and shifting and braking aren't encumbered? Link to comment Share on other sites More sharing options...
milar Posted November 8, 2019 Author Share Posted November 8, 2019 The pegs are tight. Neither lever is encumbered. I might adjust the shift lever down just a bit to compensate for the lower peg. Mike Link to comment Share on other sites More sharing options...
Lucky Phil Posted November 8, 2019 Share Posted November 8, 2019 1 hour ago, milar said: The pegs are tight. Neither lever is encumbered. I might adjust the shift lever down just a bit to compensate for the lower peg. Mike Adjusting the shift lever down probably wont help as the lever will hit the pork chop. What you need now is this. Ciao 1 Link to comment Share on other sites More sharing options...
68C Posted November 10, 2019 Share Posted November 10, 2019 I did exactly what you have done as soon as I got the bike, that and drilled headstock to accept higher bars, a comfy bike. 1 Link to comment Share on other sites More sharing options...
80CX100 Posted November 12, 2019 Share Posted November 12, 2019 Wow, nice simple tip. Not only going down but a little back as well, I can see that being worthwhile. I keep reading about the Buell pegs being a good fit,,, are they all the same or are there pegs from specific model Buells to watch for? Tks Kelly Link to comment Share on other sites More sharing options...
milar Posted November 12, 2019 Author Share Posted November 12, 2019 The part number are: N0520.1AD and N0521.1AD. Check Amazon and maybe St Paul Harley Davidson. They are available. MIke 1 Link to comment Share on other sites More sharing options...
bridge Posted July 22, 2020 Share Posted July 22, 2020 Love this adjustment! I'm wondering if you could tell me the size, length, and type of different bolt needed to replace the now too short bolt on the right side. How do you ensure the shifter can move freely when the new bolt is tightened? Thanks, Brian Link to comment Share on other sites More sharing options...
milar Posted July 22, 2020 Author Share Posted July 22, 2020 1 hour ago, bridge said: Love this adjustment! I'm wondering if you could tell me the size, length, and type of different bolt needed to replace the now too short bolt on the right side. How do you ensure the shifter can move freely when the new bolt is tightened? Thanks, Brian Sorry, but I don't recall the bolt size. You might have to do a bit of trial and error to find the right size. There is a washer between the lever and the foot peg to prevent binding. Mike 1 Link to comment Share on other sites More sharing options...
Mikko Posted July 23, 2020 Share Posted July 23, 2020 I bought these: http://motobits.com/guzzi.htm solves the shifter problem too. [docc Copied Image Location.] 2 1 Link to comment Share on other sites More sharing options...
4corsa Posted July 23, 2020 Share Posted July 23, 2020 Awesome kit! Link to comment Share on other sites More sharing options...
KINDOY2 Posted July 23, 2020 Share Posted July 23, 2020 On 11/8/2019 at 12:13 PM, milar said: After a trip to the White Mtns. last month I decided to lower my V11 LeMans foot pegs for a bit more comfort. My mechanic and I found a way to lower the stock foot pegs using existing mounting holes. It lowers them about an inch. I can gain another inch if I switch to Buell pegs. But for now, these are significantly more comfortable. Attached are before and after pics of both sides. The left side is a simple swap. The right side needs a different bolt. (Still lovin' the bike Tim! It's my go to GT bike.) Mike Doesn't it still move the peg outboard about an inch on the brake lever side? Link to comment Share on other sites More sharing options...
al_roethlisberger Posted July 24, 2020 Share Posted July 24, 2020 Well, actually this would still allow your boot to be right up against the porkchop, so I'd say "no" it doesn't cause the same pigeon toe issue as something like the Buell pegs. ...although it may feel a little odd with more than half your boot on top of the pivot and bolt instead of the peg, where in the stock location it's a bit less. Another minor consideration is that it increases the distance between the pegs and the brake & shifter, but depending on shoe size this may not be an issue. It would be curious to see more detailed photos and specs on how the bolt on the right side was handled. So this might be a good modification for some and require minimal modification, and I think I now remember this being brought up as an option in the past as well that I just forgot about. 1 Link to comment Share on other sites More sharing options...
freehme Posted July 27, 2020 Share Posted July 27, 2020 Same. I would love more details on what was involved, bolts required, etc... 1 Link to comment Share on other sites More sharing options...
bridge Posted July 27, 2020 Share Posted July 27, 2020 I ordered a Flat Socket Head Screw A2 SS - M10 x 1.50 x 80M to replace the right side bolt. I slipped a thin nut between the peg mount and the shifter so I could tighten the peg without tightening the brake pedal. So far, so good. I discovered the new arrangement also needs a 10mm (interior) x 15mm (exterior) x 20mm (length) spacer to fit the brake pedal over the bolt. One question -- now the rear brake doesn't seem to want to return to the "up" position. In other words, unless I slip my right toe beneath the lever, the brake pedal will remain down. Loss of hydraulic pressure? Or did I miss a spring somewhere? I returned the brake to normal (without the peg bolted on) and it still does not return. Please advise. Eager to ride (first time this year). Link to comment Share on other sites More sharing options...
