shaun Posted December 10, 2019 Share Posted December 10, 2019 I am in the process of awakening a sleeping beauty, V11 Sport Rosso Mandello, I have replace the fuel pump, filiter and fuel lines, all good so far I will clean the injectors this weekend. When I removed the tank and inspected the petcock it appears to be siezed, can these screwable petcock be rebuilt or is a new one needed or even available? I have checked some MG online sotres but cant seem to find one Link to comment Share on other sites More sharing options...
GuzziMoto Posted December 10, 2019 Share Posted December 10, 2019 They do come apart, at least partially. I would take it as far apart as you can get it, making sure to remove all rubber and plastic bits. Then soak it in carb cleaner or other such solvent. If you have access to a sonic parts cleaner (some use these for carb cleaning) that would be even better. If it is the manual petcock it should be salvageable. They are pretty simple devices. Link to comment Share on other sites More sharing options...
docc Posted December 10, 2019 Share Posted December 10, 2019 Even on a routine basis, these are really hard to turn. Some of us use ChannelLocks (slip-joint pliers) and some padding (like leather) to turn the things. MAybe drizzle something penetrating ("Ed'sRed!") and begin with gradual back and forth motions. Link to comment Share on other sites More sharing options...
shaun Posted December 10, 2019 Author Share Posted December 10, 2019 Thanks guys Link to comment Share on other sites More sharing options...
footgoose Posted December 10, 2019 Share Posted December 10, 2019 Yes to what Doc said, I’ve used pliers on mine since it was new. Link to comment Share on other sites More sharing options...
LowRyter Posted December 10, 2019 Share Posted December 10, 2019 I fooled myself thinking it was closed on a couple of occasions and finally figured out I needed pliers to close it. Lots of gas on the floor. Then it started leaking. So, I don't have a pet cock, just an open junction. I have a cork the might fit. I also purchased a quick disconnect but it about 5 inches long and I haven't installed it. IIRC another MG petcock is $75 or so. I think I'll leave well enough alone until I pull the tank off again. Link to comment Share on other sites More sharing options...
cash1000 Posted December 10, 2019 Share Posted December 10, 2019 Glad others have to resort to pliers to turn pet cock. Here I thought I was the only one who had to resort to that. Good idea about the quick disconnect Link to comment Share on other sites More sharing options...
Lucky Phil Posted December 10, 2019 Share Posted December 10, 2019 7 hours ago, GuzziMoto said: They do come apart, at least partially. I would take it as far apart as you can get it, making sure to remove all rubber and plastic bits. Then soak it in carb cleaner or other such solvent. If you have access to a sonic parts cleaner (some use these for carb cleaning) that would be even better. If it is the manual petcock it should be salvageable. They are pretty simple devices. The only parts that can be removed are the filter screen the attaching nut and the circlip on the end, you cant access the internals without machining/removing the crimped over top edge of the alloy operating knob. I have one of these pieces of total rubbish on the bench at the moment. I have 2 of these,one failed ( wouldnt shut off even with pliers) so I fitted the spare and its crap also. One issue is the crimped edge of the operating nut rubs on the tap body, this I rectified on the failed unit and it works much more smoothly. The major issue seems to be the seals actually swell when they contact fuel as the failed unit now its dried out for months seems to be smoother in operation and does actually close off fully now. Long story short they are rubbish quality. Ciao 1 Link to comment Share on other sites More sharing options...
shaun Posted December 11, 2019 Author Share Posted December 11, 2019 What fuel pressure should I expect at the injectors ? Link to comment Share on other sites More sharing options...
Lucky Phil Posted December 11, 2019 Share Posted December 11, 2019 36 minutes ago, shaun said: What fuel pressure should I expect at the injectors ? 3 bar, around 45 psi Ciao Link to comment Share on other sites More sharing options...
Kiwi_Roy Posted December 13, 2019 Share Posted December 13, 2019 In 2001 they had an electric petcock. Link to comment Share on other sites More sharing options...
shaun Posted December 15, 2019 Author Share Posted December 15, 2019 The bike is now running after a fuel injectors clean and new hoses, does anyone know if the fuel regulator on the RH side of the tank needs a vacuum hose on the nipple? My nipple was bare!!! 1 Link to comment Share on other sites More sharing options...
docc Posted December 15, 2019 Share Posted December 15, 2019 Cool, Shaun! Congratulations! That forward facing barb on the regulator is open; no hose. Link to comment Share on other sites More sharing options...
shaun Posted December 15, 2019 Author Share Posted December 15, 2019 5 minutes ago, docc said: Cool, Shaun! Congratulations! That forward facing barb on the regulator is open; no hose. Thanks Docc Link to comment Share on other sites More sharing options...
gstallons Posted December 18, 2019 Share Posted December 18, 2019 You know what a fuel pressure regulator is and what that nipple (usually) does . Well the V11 has it open to atmosphere . Link to comment Share on other sites More sharing options...
