nobleswood Posted November 26, 2020 Share Posted November 26, 2020 Any one have the hangers that support the mufflers & passenger pegs ? Cheers Link to comment Share on other sites More sharing options...
Twin AH Posted November 26, 2020 Share Posted November 26, 2020 I might have some........... what year are you looking for and just the black brackets? Ciao Link to comment Share on other sites More sharing options...
Lucky Phil Posted November 26, 2020 Share Posted November 26, 2020 3 hours ago, nobleswood said: Any one have the hangers that support the mufflers & passenger pegs ? Cheers I have some for the high mount mufflers. Ciao Link to comment Share on other sites More sharing options...
footgoose Posted November 27, 2020 Share Posted November 27, 2020 Stock length, V11? maybe Link to comment Share on other sites More sharing options...
nobleswood Posted November 27, 2020 Author Share Posted November 27, 2020 It's for the stock V11 2004 version. I was musing about what I wanted to do to clean up the lines of the rear of my bike. Pull the blanket of a mudshield from the tyre & install a slimmer cleaner hugger. Cut the passenger footpegs off the muffler hangers. Then fabricate a tail tidy of sorts. Change the bulbous brake light for an LED unit. Then as the beer adjusted my capacity for what is reasonable, started looking at those sexy Rizoma turn indicators. At that point I realised I'd strayed into fantasyland & went to bed So if anyone has a set lying around, of no use... 1 1 Link to comment Share on other sites More sharing options...
Lucky Phil Posted November 27, 2020 Share Posted November 27, 2020 6 hours ago, nobleswood said: It's for the stock V11 2004 version. I was musing about what I wanted to do to clean up the lines of the rear of my bike. Pull the blanket of a mudshield from the tyre & install a slimmer cleaner hugger. Cut the passenger footpegs off the muffler hangers. Then fabricate a tail tidy of sorts. Change the bulbous brake light for an LED unit. Then as the beer adjusted my capacity for what is reasonable, started looking at those sexy Rizoma turn indicators. At that point I realised I'd strayed into fantasyland & went to bed So if anyone has a set lying around, of no use... Its easy to fabricate muffler hangers with simple hand tools from 5mm aluminium plate. Better than ruining a good set of standard hangers by chopping off the peg mounts. Ciao 3 Link to comment Share on other sites More sharing options...
nobleswood Posted November 28, 2020 Author Share Posted November 28, 2020 Ah you’ve shamed me into it Whilst I can see 5 mm being stiff enough for the fore & aft loads, will that be enough for the side to side vibration ? Does there need to be a rib added ? Link to comment Share on other sites More sharing options...
docc Posted November 28, 2020 Share Posted November 28, 2020 12 minutes ago, nobleswood said: Ah you’ve shamed me into it Whilst I can see 5 mm being stiff enough for the fore & aft loads, will that be enough for the side to side vibration ? Does there need to be a rib added ? I recall a fabricator talking me out of a "rib" (or a "web") and the bracket failed. At a bad time (as always). It wasn't a V11 canister hanger, but if the question is, "Add a rib?" You have my yes. Overkill? Better than underkilled . . . 2 Link to comment Share on other sites More sharing options...
footgoose Posted November 28, 2020 Share Posted November 28, 2020 1 hour ago, nobleswood said: Ah you’ve shamed me into it Whilst I can see 5 mm being stiff enough for the fore & aft loads, will that be enough for the side to side vibration ? Does there need to be a rib added ? depends on the design I think. Two separate legs?- I agree w/docc. If fabbing a one piece "plate" (with a contoured center portion removed) I'd think that was strong enough to resist the side to side. 2 Link to comment Share on other sites More sharing options...
footgoose Posted November 28, 2020 Share Posted November 28, 2020 On 11/27/2020 at 9:41 AM, nobleswood said: It's for the stock V11 2004 version. I was musing about what I wanted to do to clean up the lines of the rear of my bike. Pull the blanket of a mudshield from the tyre & install a slimmer cleaner hugger. Cut the passenger footpegs off the muffler hangers. Then fabricate a tail tidy of sorts. Change the bulbous brake light for an LED unit. Then as the beer adjusted my capacity for what is reasonable, started looking at those sexy Rizoma turn indicators. At that point I realised I'd strayed into fantasyland & went to bed So if anyone has a set lying around, of no use... something to consider for your tail tidy. easy fab, I have more details. 1 Link to comment Share on other sites More sharing options...
Lucky Phil Posted November 28, 2020 Share Posted November 28, 2020 17 hours ago, nobleswood said: Ah you’ve shamed me into it Whilst I can see 5 mm being stiff enough for the fore & aft loads, will that be enough for the side to side vibration ? Does there need to be a rib added ? A triangular style with a centre relief cut out will be strong enough in 5mm plate ally. Ciao Link to comment Share on other sites More sharing options...
Bob Maynard Posted November 28, 2020 Share Posted November 28, 2020 2 hours ago, footgoose said: something to consider for your tail tidy. easy fab, I have more details. I’d appreciate it if you could post or email me the details for your tail tidy. My sport came with the license plate bracket mounted on the inner fender in front of the tire. I’m too old to run that setup so I’ve considered going back to stock, but I like the look of yours. 2 Link to comment Share on other sites More sharing options...
footgoose Posted November 29, 2020 Share Posted November 29, 2020 1 hour ago, Bob Maynard said: I’d appreciate it if you could post or email me the details for your tail tidy. My sport came with the license plate bracket mounted on the inner fender in front of the tire. I’m too old to run that setup so I’ve considered going back to stock, but I like the look of yours. Sure Bob. I thought I'd find a "Tail tidy" topic to place the info. This came up using a topic search. Maybe others can find it the same way. 1 1 Link to comment Share on other sites More sharing options...
loteqv11Naked Posted August 6, 2021 Share Posted August 6, 2021 Anyone have any idea where I can get the original muffler hangers? I have the Ti exhaust and Im looking for a set of replacements. Thanks! Link to comment Share on other sites More sharing options...
Twin AH Posted August 13, 2021 Share Posted August 13, 2021 So your looking for the factory cast units (long) for the 2004 Sport then? If so I may have some. Ciao Link to comment Share on other sites More sharing options...
