5 ground connectors to the negative Odyssey terminal, really?
bsanorton
As I'm reconnecting my battery at 1st I was annoyed that I had to get 4 positive connectors back on the the positive terminal, then I realized there are 5 on the ground terminal.
Ok, one is the main ground and one is the pigtail battery tender, what are the other 3 and is that a normal count?
Negatives: #1 (big one) for the main ground to the back of the gearbox, #2 for the fuel/ignition harness, #3 for the secondary harness (lights, start, charge, etc).
My other two are for an accessory plug and a GPS. I believe there are those who have grounded their regulator back to the battery (my R/R case is grounded to the timing chest).
@bsanorton, can you trace the grounds that travel outside the two factory harnesses? Look to see if there are two ring terminals on the regulator case.
Here is a pic of my 2004 Naked that is bone stock, save the more user friendly battery terminal adapters I added, showing 4 and 4 leads off the terminals, FWIW.  Don't ask me what they all are!  :huh2:
  • Thanks 2
4 + 4= #1 Main cables, #2 Fuel/Ignition harness, #3 Lighting/starting/charging harness (yes, two completely separate harnesses from the factory!), #4: something added for power access (charging or accessory power).
#5? Likely a regulator ground (second ring terminal seen on the regulator case) or a second accessory (like a GPS).
That ends up being a lot of ring terminals on the battery and a formula for corrosion and loosening. The reason some of us added junction blocks (which can also corrode and loosen!) . . .
I like the terminal adapters, where can I get some, Odyssey?
1 hour ago, Nihontochicken said:
thank you, and the lowest from amazon was $18. Your listings are the lowest, thanks!
I saw some pure copper commemorative coins about the size of a silver dollar for a dollar. Thought, "hmmm, I'm tired of fighting those stupid connections.. made a couple of angled brackets. Cheap. (Guzzi content) :D
  • Like 5
  • Haha 1
Do the connectors/cap screws contact the seat base Chuck?
1 hour ago, Chuck said:
That would be pretty exciting..
Let's hope not! I just ordered the L brackets, but got the ones that look a little beefier
https://www.ebay.com/itm/Odyssey-Battery-Copper-L-Adapter-Terminal-Brackets-Kit-Yamaha-Rhino-BMW/401458934022?hash=item5d78d13106:g:tjQAAOSw9a9gXRy6&vxp=mtr
Well not really, the base is plastic. It's a very tight fit the base clearance on these things esp the first version of the seat on the early bikes. Any contact marks on the seat base? I might consider this mod myself if the clearance is there.
