IGNORED
5 ground connectors to the negative Odyssey terminal, really?
8 minutes ago, Lucky Phil said:
Well not really, the base is plastic. It's a very tight fit the base clearance on these things esp the first version of the seat on the early bikes. Any contact marks on the seat base? I might consider this mod myself if the clearance is there.
That's a great observation and question. And caution for those who have done modification this to inspect their seat base for fouling. I have had to relieve my seat base for several clearance issues and know others have, as well. Simple enough with a Dremel, sometimes replacing polymer panels to cover the underside of any exposed foam.
Definitely do not want our seat bases sitting on our battery terminals.
Link to post
I'm pretty careful about that kind of stuff.. but I went out and got my modeling clay. Unfortunately, it's gone missing :rolleyes: but it *appears* to have plenty of clearance. Plastic or not, pressure on those posts would not be a good thing..
Link to post
Ok thanks Chuck. I was very surprised at how tight the original base was on my bike. I made a simple aluminium extension strap so the runner battery strap wasn't pulled so tight and that wouldn't allow the seat to clip down because the metal ring on the rubber strap now sat flat on the battery top, sheez. I tried my later seat and it definitly has more under seat clearance to things and a simpler cleaner detail design.
Link to post
25 minutes ago, Lucky Phil said:
Ok thanks Chuck. I was very surprised at how tight the original base was on my bike. I made a simple aluminium extension strap so the runner battery strap wasn't pulled so tight and that wouldn't allow the seat to clip down because the metal ring on the rubber strap now sat flat on the battery top, sheez. I tried my later seat and it definitely has more under seat clearance to things and a simpler cleaner detail design.
I remember relieving a ridge on my original seat pan because it was cutting the battery strap. I bought a second hand seat later and the PO had cut out the entire battery area to the exposed foam (makes the seat pan pretty flimsy).
My solution to the seat pressing the battery was to attach the battery basket to the bottom of the subframe at the front, gaining maybe 3mm to 5mm.
Link to post
Good idea docc, might try that next time I have the battery out.
Link to post
A couple things made me nervous about making that change. One was shock clearance (it's tight down there!) . . .
The other was the nuts loosening and the bolts dropping out, then the battery and basket dropping onto the shock sending me halfway to a bad day. Pretty sure I either used NyLoc nuts or LocTite or both. :blink:
Link to post
Pretty sure I learned this set-up from :notworthy: Andy (along with a boat load of other stuff . . .).
Okay, I remember now that the bolts screw up through the threaded nuts welded to the underside of the subframe. I was still nervous about them loosening and topped them with flange nuts. The bolts are too short to fully engage the "locking" nuts, so I drenched them in blue LocTite. Like Andy, been there > a long time < . . .
I just measured and this drops the front of the battery basket 0.360"/ ~9mm (almost 3/8"! because of the thickness of the basket metal plus the thickness of the subframe plate and the thickness of the welded nuts underneath) . . .
Link to post
I did the same docc, and got a bit more by bending the tab some
Link to post
No marks on my seat base (2004 Naked) from the battery L post adapters, but then I weigh only about 150 pounds all suited up.  Real men may have a different experience. :lol:
  • Haha 1
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
