BrianG Posted October 23, 2021 Share Posted October 23, 2021 Looking for the engine block "flange" for a 2004 V11S. This is the casting between the engine block itself, and the engine oil sump casting. PO broke out the side stand mounting bolt boss. Parts diagram pg 34.31 part #25GU01003240 flange black Link to comment Share on other sites More sharing options...
MartyNZ Posted October 23, 2021 Share Posted October 23, 2021 How about this Adapter Oil Pan Moto Guzzi V11 Le Mans | eBay or Moto Guzzi V 11 Le Mans KS Bj 2003 - Oil pan intermediate ring engine cover A28G | eBay Link to comment Share on other sites More sharing options...
fotoguzzi Posted October 23, 2021 Share Posted October 23, 2021 I have one from a Centauro, would that fit? Link to comment Share on other sites More sharing options...
BrianG Posted October 23, 2021 Author Share Posted October 23, 2021 Do you know what year of Cenrauro it's from? Link to comment Share on other sites More sharing options...
fotoguzzi Posted October 23, 2021 Share Posted October 23, 2021 1997 Link to comment Share on other sites More sharing options...
BrianG Posted October 24, 2021 Author Share Posted October 24, 2021 That's an 1100 ? Link to comment Share on other sites More sharing options...
fotoguzzi Posted October 24, 2021 Share Posted October 24, 2021 It's from a V10 Centauro.. I "think" the block and sump are the same as the V11 Link to comment Share on other sites More sharing options...
BrianG Posted October 26, 2021 Author Share Posted October 26, 2021 It seems that the part number is 01003240 not the 01003202 that yours is. But thanks for the offer. Brian G Link to comment Share on other sites More sharing options...
docc Posted October 26, 2021 Share Posted October 26, 2021 1 hour ago, BrianG said: It seems that the part number is 01003240 not the 01003202 that yours is. But thanks for the offer. Brian G That is likely just the difference in the color. The same part for the 2002 LeMans (wrinkle black): 01003240 For the 1999-2001 Sport (silver color): 01003202 2001 Rosso Mandello (smooth black): 01003240 Here is one from a 2003 LeMans (black like your 2004) on US ebay parted out from Germany: Moto Guzzi V 11 Le Mans KS Bj 2003 - Oil pan, intermediate ring, engine cover A2 Link to comment Share on other sites More sharing options...
BrianG Posted October 26, 2021 Author Share Posted October 26, 2021 That's interesting information. What would you be asking for this piece? Link to comment Share on other sites More sharing options...
fotoguzzi Posted October 26, 2021 Share Posted October 26, 2021 Brian, I'd be willing to send it to you no charge to find out if will work. If it does I'll take whatever you want to offer. but like Docc says it's a different color, I'd call it gun metal gray. you can have the sump cover too in grey paint if you want. 1 Link to comment Share on other sites More sharing options...
fotoguzzi Posted October 26, 2021 Share Posted October 26, 2021 15 minutes ago, BrianG said: That's interesting information. What would you be asking for this piece? Make an offer after you know it works. I'll send it to you no charge. Link to comment Share on other sites More sharing options...
pete roper Posted October 26, 2021 Share Posted October 26, 2021 All the 'Broad Sump' components are identical physically between the assorted bikes that use the system. As noted, the difference is simply the colour. Foto is offering a 'Try Before You Buy' deal on a part that hasn't been available for years ex factory. I'd grab it with both hands and be amazed that you have been kissed on the arse by a golden fairy! 1 1 Link to comment Share on other sites More sharing options...
Lucky Phil Posted October 26, 2021 Share Posted October 26, 2021 1 hour ago, pete roper said: All the 'Broad Sump' components are identical physically between the assorted bikes that use the system. As noted, the difference is simply the colour. Foto is offering a 'Try Before You Buy' deal on a part that hasn't been available for years ex factory. I'd grab it with both hands and be amazed that you have been kissed on the arse by a golden fairy! Actually Pete there is one semi significant difference. Some have an 8mm side stand bracket threaded mount bolt hole and some have a 6mm bolt which can be a bit of a pain if you have the wrong one as I did when I did the V10 Sport. Didn't realise until I went to refit the side stand bracket. It's not straight forward opening up the 6mm side stand bracket hole to accommodate the 8mm cap screw head. Not without a mill anyway. Ciao 1 2 Link to comment Share on other sites More sharing options...
pete roper Posted October 26, 2021 Share Posted October 26, 2021 OK. I stand corrected. Link to comment Share on other sites More sharing options...
