John Neeson Posted July 23, 2022 Share Posted July 23, 2022 Hello All, Does anyone know how to remove the cylinder head oil feed.(1100 engine). There is not enough clearance between the bolt and the fins to get a spanner on it. Link to comment Share on other sites More sharing options...
docc Posted July 23, 2022 Share Posted July 23, 2022 You are speaking of the fastener that holds the double banjo fitting into the front of cylinder valley between the cylinders? The one on myV11 uses a 13mm spanner to turn it. I just put a common 10º offset ring spanner ("box end wrench") on mine from the left side ahead of the cylinder. And found it just barely tight! Gave it a snug and finished tightening with another ring spanner that has a 30mm offset. Both spanners gave me enough swing and leverage to turn the fastener. Perhaps the earlier 1100 Sport-i differs? Maybe @Pressureangle will come along to chime in . . . In the meantime, thanks @John Neeson for bringing this loose fastener to my attention!! Link to comment Share on other sites More sharing options...
Pressureangle Posted July 23, 2022 Share Posted July 23, 2022 I just checked- I've never had them off on the 'Sport, mine are identical to those on the '85 LM1000. That is to say, they're a PITA but can be removed with common end wrenches. Some wrenches are thinner and smaller than others, could play havoc. Or the later bikes may have a different connection altogether. I got nothin'. 1 Link to comment Share on other sites More sharing options...
docc Posted July 23, 2022 Share Posted July 23, 2022 I just looked at the feeds at the cylinder head, itself. Looks like I could get on those with a thin "open-end" 14mm spanner if the tank and airbox were removed . . . Link to comment Share on other sites More sharing options...
Lucky Phil Posted July 23, 2022 Share Posted July 23, 2022 4 hours ago, docc said: You are speaking of the fastener that holds the double banjo fitting into the front of cylinder valley between the cylinders? The one on myV11 uses a 13mm spanner to turn it. I just put a common 10º offset ring spanner ("box end wrench") on mine from the left side ahead of the cylinder. And found it just barely tight! Gave it a snug and finished tightening with another ring spanner that has a 30mm offset. Both spanners gave me enough swing and leverage to turn the fastener. Perhaps the earlier 1100 Sport-i differs? Maybe @Pressureangle will come along to chime in . . . In the meantime, thanks @John Neeson for bringing this loose fastener to my attention!! There special tools for this Banjo. Not all engine blocks are machined the same at the banjo oil feed point and even a thin walled spanner or socket won't fit on some engines. I know because I have 4 sets of cases at home and the machining clearance for the banjo fitting is quite a bit different on a couple of them. The tool on the top LHS is one I made for removing oil pressure switches on Daytona engines. It's between a long and normal socket in length. The others are for the Banjo. Why two tools for the banjo? Because the "swing" is restricted down in the "V" and to get that last 1/2 flat rotation you sometimes need the socket. Phil 1 2 Link to comment Share on other sites More sharing options...
John Neeson Posted July 24, 2022 Author Share Posted July 24, 2022 Should have made it clearer. Problem is not the banjo, but the other end where it fits on to the cylinder head. (I have the engine on the bench) 1 Link to comment Share on other sites More sharing options...
Scud Posted July 24, 2022 Share Posted July 24, 2022 Are we talking about the oil lines that feed directly into the head as in this picture? If so, you just need a slim spanner (wrench) - not a big clunky one. If you have a cheap spanner that you don't care much for, you can grind it down till it fits. (disregard the measure tape - that was for a different purpose a while back, but it's the only pic I could find of the fitting in question) 2 1 Link to comment Share on other sites More sharing options...
John Neeson Posted July 24, 2022 Author Share Posted July 24, 2022 That's the one! I found something on Amazon that should do it. Thanks to all who responded. 1 Link to comment Share on other sites More sharing options...
MartyNZ Posted July 24, 2022 Share Posted July 24, 2022 21 hours ago, docc said: ...a 13mm spanner to turn it. I just put a common 10º offset ring spanner ("box end wrench")... Our moderator is multi-lingual! Awesome 👍 1 4 Link to comment Share on other sites More sharing options...
