Guest ckamin Posted January 4, 2006 Share Posted January 4, 2006 Although I am in California, I am all about how my bike runs/performs and engine life/longevity. Which specs should I set the valves at and anyone have any specific recommendations or suggestions? Thanks in advance! -Carl Link to comment Share on other sites More sharing options...
Skeeve Posted January 4, 2006 Share Posted January 4, 2006 Although I am in California, I am all about how my bike runs/performs and engine life/longevity. Which specs should I set the valves at and anyone have any specific recommendations or suggestions? Thanks in advance! -Carl 73035[/snapback] Consensus is that Euro spec is the minimum for decent performance, w/ the Raceco specs at the upper end. Ride on! Link to comment Share on other sites More sharing options...
dlaing Posted January 4, 2006 Share Posted January 4, 2006 I put on my website: Clearance specs (US): intake: 0.002" (0.05mm), exhaust: 0.004" (0.10mm) Clearance specs (rest of world): intake: 0.004" (0.10mm), exhaust 0.006" (0.15mm) I like mine set to 0.006"(0.15mm) intake and 0.008"(0.20mm) exhaust. RaceCo recommends 0.008"(0.20mm) intake and 0.010"(0.25mm) exhaust But I got to thinking the manual says intake: 0.004" (0.10mm), exhaust 0.006" (0.15mm) in every language. So the "US spec" maybe the same as the "World spec" I think the term "US spec" originated in other Guzzis Can anyone verify? In any case any spec other than the US spec is good enough. One person suggested they got better fuel consumption at intake: 0.004" (0.10mm), exhaust 0.006" (0.15mm) Others suggest the bike idles better with more gap. YMMV Link to comment Share on other sites More sharing options...
Alex-Corsa Posted January 4, 2006 Share Posted January 4, 2006 RaceCo recommends 0.008"(0.20mm) intake and 0.010"(0.25mm) exhaust Is it perhaps so when using their own Valve kit (and or with some mods in the valve seats)???? And not the OEM Guzzi? AFAIK is OK to be a bit more than less. Link to comment Share on other sites More sharing options...
dlaing Posted January 4, 2006 Share Posted January 4, 2006 Is it perhaps so when using their own Valve kit (and or with some mods in the valve seats)???? And not the OEM Guzzi? AFAIK is OK to be a bit more than less. 73074[/snapback] I don't think so. They wrote the following on their website http://www.raceco.com/tech.html Tappet clearances for two and four valve enginesTwo valve engines Tappet clearances for the Guzzi big twins should be set to 0.20mm for the inlet and 0.25mm for the exhaust. This also applies to the "modern" Guzzis such as the Sport 1100, Cali 1100i and V11. The factory settings for these bikes are 0.10mm and 0.15mm respectively, but this is to try and reduce engine noise to meet US emissions regulations. With tappets set this tight the engines have trouble ticking over and running cleanly at low revs. Link to comment Share on other sites More sharing options...
Guest trispeed Posted April 2, 2006 Share Posted April 2, 2006 I have a california spec, 2004 v11 sport. the sticker on the bike says .15mm IN and .20 ex.; where did this .05/ .10 spec come from? older models, I suppose? Link to comment Share on other sites More sharing options...
rocker59 Posted April 6, 2006 Share Posted April 6, 2006 I have a california spec, 2004 v11 sport. the sticker on the bike says .15mm IN and .20 ex.; where did this .05/ .10 spec come from? older models, I suppose? 84667[/snapback] My 1996 Sport 1100 Owner's Manual, on page 138, recommends: *intake valve: 0.10mm *exhaust valve: 0.15mm *USA version: intake valve: 0.05 exhaust valve: 0.05 (The "modifications" insert that I have in the Owner's Manual for the 1997 injected Sport 1100 recommends intake 0.05mm/exhaust 0.10mm). (I run my carb'd Sport at the "Euro" 0.10mm intake/.15mm exhaust and it is much happier... and tappier!!!) My Nero Corsa's Owner's Manual, on page 172, recommends: Intake valve 0.10mm Exhaust valve 0.15mm (the sticker on the rear "hugger" mud guard recommends .15 and .20 !!!) Link to comment Share on other sites More sharing options...
Baldini Posted April 7, 2006 Share Posted April 7, 2006 ...Is it perhaps so when using their own Valve kit .... For all bikes I think. I spoke w/ Amadeo (Raceco) long time back & he told me 0.20mm in/0.25mm ex was best for my stock V11 (as Dave notes from their website). They used even bigger clearances on their racebikes. Note that Guzzi spec'd 0.22mm (.0086") clearance both in & ex on old Tontis. KB Link to comment Share on other sites More sharing options...
jrt Posted April 7, 2006 Share Posted April 7, 2006 I have a california spec, 2004 v11 sport. the sticker on the bike says .15mm IN and .20 ex.; where did this .05/ .10 spec come from? older models, I suppose? 84667[/snapback] I think the smaller values are an attempt to cut down on engine noise and pass stricter noise regulations. I could be wrong, but that's my impression. Link to comment Share on other sites More sharing options...
