BrianG Posted January 19, 2007 Share Posted January 19, 2007 I am going to change the front brake master cylinder to a Brembo 19X29 radial unit. I need to know if the handle bar diameter is 7/8 or some metric value. Does anyone know for certain? Any opinions on the selected specs? Link to comment Share on other sites More sharing options...
Guest Gary Cheek Posted January 19, 2007 Share Posted January 19, 2007 22mm Link to comment Share on other sites More sharing options...
Tom M Posted January 19, 2007 Share Posted January 19, 2007 I bought my bike with a radial Brembo MC that was purchased from Todd at Guzzitech (RacerX on this board). I'm sure he can tell/sell you exactly what you need I believe the handlebars are 7/8" dia which is 22.22mm. Link to comment Share on other sites More sharing options...
Guest Gary Cheek Posted January 19, 2007 Share Posted January 19, 2007 My V11 Sport measures 22mm not 7/8" Link to comment Share on other sites More sharing options...
Skeeve Posted January 19, 2007 Share Posted January 19, 2007 My V11 Sport measures 22mm not 7/8" 22mm is only .225mm less than 7/8"; that's only about .866", which is well within most production tolerances for 7/8" (.875") bars & controls, I'm guessing. For all practical purposes, approximating pi by using 22/7 is about the same sort of imprecision as swapping 22mm & 7/8". Yeah, they aren't equal by any stretch, but there's such a thing as "close enough." Now, for missions to Mars, swapping SAE & metric isn't kosher: for attaching bicycle parts to your moto bar mounts, yeah, it's within tolerances... Link to comment Share on other sites More sharing options...
Guest Gary Cheek Posted January 19, 2007 Share Posted January 19, 2007 22mm is only .225mm less than 7/8"; that's only about .866", which is well within most production tolerances for 7/8" (.875") bars & controls, I'm guessing. For all practical purposes, approximating pi by using 22/7 is about the same sort of imprecision as swapping 22mm & 7/8". Yeah, they aren't equal by any stretch, but there's such a thing as "close enough." Now, for missions to Mars, swapping SAE & metric isn't kosher: for attaching bicycle parts to your moto bar mounts, yeah, it's within tolerances... About .009'. It is enough of a difference to require shimming on many .875" or 7/8" accessories when used on 22.0 MM bars. Many 7/8 twist grips will roll about on 22mm bars . Some folks do prefer no-fuss applications, if you want a good fit use a good dimension. Tolerances stack up, a large "7/8 inch" and a small "22MM" equals a beer can shim. He asked if it was 7/8 or some metric value. It is a metric bar,22millimeters Link to comment Share on other sites More sharing options...
