breakdown of model year changes
  • This topic is locked This topic is locked
1 reply to this topic
#1 jrt
jrt
    "I live here"
  • 4,436 posts
  • My bike(s):
    '01 V11 Sport
    Back in St. Louis
Posted 05 August 2005 - 05:09 PM
Interested in buying a V11?
See this faq and the 'most common problems' faq
This addresses the changes in V11 Sports and LeMans motorcycles from 1999-2003
Thanks and credit goes to the many V11LeMans website contributors.
Breakdown of changes in year models from 1999-2005.
The V11 sport variants (referred to here as just 'V11') have been produced from about '99 to 2005. I understand that this model is now discontinued, and will no longer be built. That makes it a legacy bike, I guess.
Major similarities: All the V11 models are 'spine frame' bikes. The name derives from the large square 'spine' that runs the center of the bike between the cylinders and serves as the main frame component. All the V11 variants have the normal Guzzi two cylinder, two valve/cylinder motor that is in a higher state of tune than the 'cruiser' model Guzzi's. The valves must be adjusted- they are not hydraulic.
All the V11 variants have the six-speed transmission and a hydraulic clutch. Older spine frame Guzzi's like the 1100 sport, 1100sporti, etc. have a 5 speed box.
Real changes in the bikes from inception to end are small and incremental.
1999-2001 models have a (shorter) red frame and have steeper steering geometry than later models (except RM). They handle 'quicker' or some say 'more twitchy'. Some say they are unstable at high speed- I've never had a problem. The 99-01 models have clip-ons mounted below the upper triple clamp and have Veglia (brand) instruments. They have a thinner rear tire (4.5") and the brake rotors have circular holes in them; apparently the 'circular hole rotors' are more prone to warping than later rotors. My mid-year '01 has later model rotors fitted, so your guess is as good as mine here.
Guzzi went to a longer wheelbase in late '01 or '02 to increase high speed stability. The '01 Rosso Mandello still has the short wheelbase of the 00 V11, only the rake of the fork was relaxed a little, about a half a degree. This kept the steering quick, but a little less twitchy at high speeds. Some folks have suggested that appropriate tire choice (Pirelli Diablo) gives a machine that handles like the '00-01 models. '02 and later models have additional bracing in the frame and a wider 5.5" rear wheel. New front forks with the clip-ons mounted above the triple clamp are standard. '02 and later models have black engine paint. The '02 model paint is 'fuzzy' and is prone to flaking and blistering off- so it looked horrible- and Guzzi offered new cases to those afflicted with it. New brake rotors (triangular holes) are stock.
Late '02 models have commonly been rebadged as '03 models. True '03 models should have a '3' in the VIN and have 'satin' engine paint. Fuzzy engine paint on an '03 model is an indication that it is a rebadged '02.
In '02 or '03, Guzzi changed the electric gas petcock out for a manual version.
'03 was a 'big' year for changes in the V11; many improvements were made. Fork diameter is larger, front axle diameter is larger and the axle is hollow. A front crossover or balance pipe is added above the alternator (improves midrange performance). The engine has a *claimed* higher compression set of pistons, which are now cooled by an oil jet (more on this below). The fuel pump was relocated to the interior of the gas tank, so '03+ models do not suffer from vapor lock like earlier models (see below). Several cosmetic modifications are present as well- the 'chin pad' is gone in favor of a smooth tank. The engine paint is satin black, the fairing (if present) mounts further ahead on a different 'gooseneck' mount. Gauges are now ITT brand. This interesting trivia from the V11 board:
"I would like to add a note about the speedo on the 02 - 03 V11 Naked. This may or may not be common knowledge. The original and replacement speedos on my bike did exactly the same. The bottom line is that the speedo indicates in MPH, the trip-odometer registers in miles but the odometer registers in 2KM increments. If you don't believe me and have one of these bikes, pull off and stop when the odometer just finishes turning to a new number and set the trip to zero. Drive the bike until the odometer just turns an additional "10 miles". You will find that the trip reads just over 12.4 miles or exactly 20KM. "
All that said- Guzzi has been known to make 'parts bin' bikes out of whatever is left over. In that case, the bike may have parts from several year models. This can be frustrating, but it attests to the fact that most parts from one year will fit on other year models.
Decoding the VIN number (thanks to Todd Haven of MPH Cycles)
Z is for Italy
GU is for Guzzi
KRAKR designates 1100 spine frame 2000-2002(sport and Lemans)
9th digit is undefined
10th digit is model year(not production)
W-98, X=99,Y=2000,1=2001,2=2002
11-16th digits are identifying serial number for your specific bike.
  • nuevototem and mjseymo like this
#2 Admin Jaap
Admin Jaap
    Chief whip
  • 6,056 posts
  • My bike(s):
    '08 1200 Sport
    Varsseveld - NL
  • Visit my Facebook profile
  • Follow me on Twitter
  • Visit my LinkedIn profile
Posted 21 January 2007 - 12:39 PM
1999-2001 (Red frame models)
Posted Image Posted Image
Posted Image
Rosso Mandello - Limited edition, total 600 made
Posted Image
2002
Scura
Posted Image
Tenni
Posted Image
Le Mans
Naked
Posted Image
2003-2005
Rosso Corsa
Posted Image
Nero Corsa
Posted Image
Le Mans
Café Sport
Posted Image
Ballabio
2004 - 2005
Coppa Italia
Posted Image
2005 - 2006
Scura R
Posted Image
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
