Alfanatiker
    2
Alfanatiker last won the day on July 6 2015
Alfanatiker had the most liked content!
About Alfanatiker
  • Birthday 09/18/1955
    2002 V11 LM, 2006 BREVA V1100ABS
Alfanatiker's Achievements
Guzzisti
Guzzisti (2/5)
3
  1. Bjorn, http://smotos.de has two used gearboxes => http://smotos.de/Ersatzteile/Getriebe_Teile.pdf
  2. Try these instead of OEMs - they also look better than NGKs http://www.ebay.com/itm/2x-Champion-PRO5U-Spark-Plug-Caps-2-silicone-5-K-Ohm-resistor-plug-covers-/111994133744?hash=item1a135edcf0:g:7GAAAOSwcL5XM0VI&vxp=mtr
  3. My Mistrals w and w/o db-killers ...the "white" is ceramic grease.. ....but beware: you absolutely wouldn't want to drive behind yourself without the db-killers in Gunther
  4. I think so also. But the rarest is the 146 with the 16V Boxer. Only 4800 pcs. have been built worldwide. I bought a 146 in '95 new and gave her in exchange for one of the first 156 in autumn '97 . Following years i was unhappy with this deal, i missed the sound and the tingling on my a.. of the Boxer. In 2009 i randomly found a 146 Boxer for sale on the net - she was the mine and i bought her back.
  5. Living 10 kms next to the italian border it isn't possible not to drive italian cars. Mine are Alfas, as i current have: 159SW TBi, Brera V6, 146 16V 1,7 Boxer my 95 and a well preserved Bertone (2000 GT Veloce) my 71. And as heritage from my father a MB W123 230CE, mj 76.
  6. A member of the german V11 forum has fitted a LED Headlight from truck-lite (with pics) http://www.v11sport.de/forum/viewtopic.php?f=11&t=6646 Gunther
  7. Mannaggia la pioggia!!
  8. Mannaggia la pioggia!!
  9. Gratulazioni! La ottima moto per viaggiare senza mal di schiena. L'anno scorso ero quattro settimane con la mia Breva in Sicilia e Sardegna (5000km), quest'anno sei settimane in Grecia, Turchia, Bulgaria, Ucraina e Romania (8500km). Senza Problemi, con la V11 (attualmente il cambio è rotto) che sarebbe impossibile. mandi Gunther
  10. Had the same few times on my Breva. In my experience it's a bad connection -batt to frame combined with the circumstance that the dashboard (where the "battery" voltage is measured) doesn't have an own wire directly to neg. batt. e.g if the wire (+cable lugs + screws) from neg. batt --> frame has 0,05 ohms (the starter motor consumes an average starting current of 100 amps / series wound motor) you will have a voltage drop of ~5 volts on this connection at the moment of starting. CARC starting procedure is: startbutton --> + --> input ECU then output ECU + --> to starter solenoid. If dashboard detects "low voltage" it sends "stop starting" over CAN to ECU and you will hear the wellknown "klack". I did an additional wire of 6 mm² (AWG 10 or 9) from neg.batt --> fastening screw generator --> fork and never again heard "klack".
  11. some years ago afair guys of the german forum made mixed tests on a dyno with several exhausts, crossovers, airboxes (with holes drilled in it) and open filters but w/o remapping. Every test ended with less power and/or less torque. Luigi and Mario aren't silly . So, if you change anything at air-intake or exhaust and you wanna get maximum out of the engine you have to remap. Gunther
  12. Here it's on stock (#24, the upper one): http://www.wendelmotorraeder.de/schaltung-v11-mansskura-ex-30_3006_300602_30060203_3006020330_300602033012.html If you wanna order it write to info@wendelmotorraeder.com. They deliver with DHL. To save time and money for p+p tell them not to send as a parcel but as "Maxibrief international" (https://www.deutschepost.de/de/b/briefe-ins-ausland.html). Think, 5-10 days and you will have your "Ratchet" Gunther PS: http://www.tlm.nl/webshop/en/ratchet-v11-012351300000-moto-guzzi , p+p to US 35,00 EUR, holidays til 18th Aug.
  13. Some good short cuts there. I never managed to get the PAWL arm off with the cam gears in place. Must be a knack to it. You have to remove the limit stop of the ratchet. There are two versions: 1st with a spring pin (as it has mine) - pull it out with a pliers 2nd with an excentric bolt (from VIN KT111436) - remove it by unscrewing the nut on the outside of the cover - remember its position and don't loose the gasket. "turn out" the ratchet from under gearwheel #14 ...... (holy sh.., my English ;-) Ok? Gunther
  14. First of all remove neg. from battery. On the roadside it's not necessary to drain the oil. Lay the moto on the right side - ~30 deg from horizontal will be enough. ........ After opening the gearbox DON'T touch or move the gear forks! Take the cover and mark the position of gearwheel #12 to gearwheel #14 exactly (tooth to tooth) Remove #12 Don't touch or (re)move the gearwheel #14! ....... Change spring Attach gearwheel #12 in the former position. ...... Close box.... and drive Gunther
