H4 LED + other LED lighting
docc
Well, as noted, I've seen H4 LED with as little as 1000 lumen and as much as 8000. The standard incandescent hi-beam is around 1850.
One member in the other thread (I believe Moto fugazzi) commented that the blue-white light is not as effective as the warmer (more yellow) color in rain and fog. I've heard similar comments from the automotive side.
(Sw'dave, I have one of the LED tail light units you posted elsewhere, but haven't installed yet.)
So the $20 bulb puts out 200 lumen and the regular one is 1850 and you're complaining?
The blue/white is very effective at one thing, drivers seeing you.
It seems like if I'm going to go to the trouble to "upgrade", I would want a significant difference in output. I realize that the cost, and the heat, rise with the output, while longevity/reliability go down.
I didn't mean to start a separate headlight thread, as I was hoping the member who had posted an alternative LED would post up. It wasn't posted on the JBBenson's main thread, but somewhere else.
Still, I appreciate all the links and the education. At this point, I would like to find a heat sink (no fan) unit with 4000+ lumen and color range less than 5000 Kelvin.
Ain't hard to figure out how much space you have in the bucket. But I'd be surprised if you had 35mm.
HTB1XwhhLFXXXXb5XFXXq6xXFXXXj.jpg?size=7
My best methods yield *right-at* 45 mm from the H4 base plate to the back of the bucket.
If the fan exhausts backward through the honeycomb, maybe a vent cut in the back of the bucket would be exactly right?
If the fan exhausts radially, then it's simply a close fit (10 mm behind the heat sink/ fan housing).
What they don't show you is the wiring required for that light. Well, they show it but not attached.
Truly. I have been trying to discern the wiring. The connector to the driver *looks* very similar to the AMP connector for the V11 headlamp, but it's not the same. What to cut and solder this time? That would be far from "plug&play ". . . .
sorry.  do we have an answer?
Depends on the question(s), I suppose.
I have the 4000LM/4300K "bulb" on the way.
*[edit 6 June 2017: this unit plugs in with any wiring changes, everything fits easily in the early Bosch bucket, actaul 10-11 mm clearance behind the heat sink/ fan outlet.]
The unit that MartyNZ posted with the copper coils looks like it works, "plug&play," if you're okay with the output and the color.
I thought Swoosh made a good point about the white/blue lights perhaps being more visible to other road users.
Yet, I personally prefer to  look out upon the road with a warmer (more yellow) light. I figure if it's bright enough, it will still have good conspicuity.
After all, cagers still pull in front of fire trucks painted Safety Yellow with lights and sirens going . . . :glare:
  • 2 weeks later...
So, this unit came today. Twelve days (including two weekends and a US holiday) from China.  :thumbsup: The unit was packaged very well and looks to be very high quality. The driver is integrated with the plug, so it is indeed a plug in unit. Just a matter of grooming the wiring and small driver in the bucket.
There is ~10-11 mm (3/8") behind the fan outlet/ heat sink housing. I'm pleased with that (so far!)
