bbolesaz Posted August 25, 2017 Share Posted August 25, 2017 At least that what the little green light thought rolling down the Loop 202 this morning. Guessing a shorted wire somewhere or maybe the switch is backing out of the hole. Add it to the list for this weekend. Link to comment Share on other sites More sharing options...
Lucky Phil Posted August 26, 2017 Share Posted August 26, 2017 At least that what the little green light thought rolling down the Loop 202 this morning. Guessing a shorted wire somewhere or maybe the switch is backing out of the hole. Add it to the list for this weekend. Remember its made in Italy, the neutral light lives an independant life of its own and answers to no one:) Ciao Link to comment Share on other sites More sharing options...
luhbo Posted August 26, 2017 Share Posted August 26, 2017 The red one comes on after half an hour in the rain. Only white is still missing, so we have still room for improvements. Link to comment Share on other sites More sharing options...
gstallons Posted August 26, 2017 Share Posted August 26, 2017 Look around where the wire the N light connector plugs in to the switch and follow the wire as far as you can looking for pinch points , cuts or signs of abrasion . If this is ok then unplug the connector and ride for one day . IDK how long it "normally" takes to flicker or come on . If it does come on the problem is still in the wiring harness somewhere . If the light remains out , the problem is in the switch . 1 Link to comment Share on other sites More sharing options...
gstallons Posted August 27, 2017 Share Posted August 27, 2017 And if you will put this test first . Check the push on connector of the N switch wire . IDK why I didn't post this in the post . Link to comment Share on other sites More sharing options...
bbolesaz Posted August 28, 2017 Author Share Posted August 28, 2017 Well on my ride home from work Friday, there was no neutral light except when I was actually in neutral. Today I tracked along the wiring and found no problems. The switch itself looks odd. I don't see how it gets threaded into the tranny case and it's an odd red color. Does anyone have a pix of what the neutral switch should look like? Link to comment Share on other sites More sharing options...
bbolesaz Posted August 28, 2017 Author Share Posted August 28, 2017 Found a pic of what the neutral switch should look like. Apparently, on my bike, a P.O. decided to put red RTV pookie all around the switch and fill up the hole. I guess it was leaking and this was their bright solution. I'm sure it's going to be big fun to dig all of that pookie out of the selector cover when it comes time to replace the switch. Link to comment Share on other sites More sharing options...
bbolesaz Posted August 28, 2017 Author Share Posted August 28, 2017 BTW, what has to come off of the bike before one can remove the gearshift selector cover and guts? I'm assuming remote shock reservoir and starter motor. Link to comment Share on other sites More sharing options...
coreytrevor Posted August 29, 2017 Share Posted August 29, 2017 I take off the shifter and linkage too. Don't forget to disconnect the battery ground first. And you can slightly loosen the breather oil return fitting on the sump so you can move the hose further out of the way. Link to comment Share on other sites More sharing options...
