docc Posted April 21, 2019 Report Share Posted April 21, 2019 Getting ready for a ride to the Appalachians in a month and found a weak rear Pirelli GT. They are lasting about 3500 miles for me; right at average for my 30 rear tires. (I get 3 rear : 4 front). Trying to follow my own advice (Wheels Off Maintenance Checklist in FAQ) , I found my Brembo rear pads ready for a change (10,111 miles/ 16.300 km). Inboard more than outboard, which tells me the pistons need cleaned, equalized, pin polished and lubed, and fluid bled. The brake side rear wheel bearing was also played up. Fourth one on that side. Only the third on the drive side, which felt okay, but my trusted friend, Josh, who found the bad bearing says, "Change them both." I believe in this guy! The last bearings were made in China and lasted 1/2 as long as the OEM, Euro-made stuff. I'm trying to source better made bearings. So . . . when that tire needs changed, folks: Wheels Off Maintenance Checklist! 2 Link to comment Share on other sites More sharing options...
Lucky Phil Posted April 21, 2019 Report Share Posted April 21, 2019 Yes docc source some decent brand bearings, Timken, SKF, Koyo etc. After you install the new bearings can you report back on how the bearing feels to turn by finger. I suspect these may actually need bearings with C2 or C3 clearance for greater life. ciao 2 Link to comment Share on other sites More sharing options...
czakky Posted April 21, 2019 Report Share Posted April 21, 2019 I seem to replace bearings at every 3rd or fourth tire change. Always use SKF most of the time. Usually bearing condition isn’t horrible but not worth the risk of running a shagged bearing. FWIW. 1 Link to comment Share on other sites More sharing options...
gstallons Posted April 21, 2019 Report Share Posted April 21, 2019 Huh ? Link to comment Share on other sites More sharing options...
czakky Posted April 21, 2019 Report Share Posted April 21, 2019 3 hours ago, docc said: Something needs a bit of clarification? My post was a little jumbled. Sorry ‘merican public schools and all. Its been edited. Link to comment Share on other sites More sharing options...
docc Posted April 21, 2019 Author Report Share Posted April 21, 2019 1 hour ago, czakky said: My post was a little jumbled. Sorry ‘merican public schools and all. Its been edited. Ah, okay. I thought my initial post was kinda busy and went some different directions. But that's what inspection during maintenance can do . . . Clutch reservoir looks low. Closer inspection reveals the replacement slave cylinder is weeping. Now, I am too. I suppose I can install my original while waiting for bearings and brake pads . . . Link to comment Share on other sites More sharing options...
gstallons Posted April 21, 2019 Report Share Posted April 21, 2019 Buddy , with bearings now . I don't know which brand is best . I would buy SKF deep groove bearings . I used to have that info in the basket next to me but..... Just make sure it is not Made in China . Everything from chewing gum to dog food is made there now . UGH ! 1 Link to comment Share on other sites More sharing options...
docc Posted April 22, 2019 Author Report Share Posted April 22, 2019 Trying to get a couple of the Guzzi dealers to tell me who makes their available bearings and where they are from. Last Timken we saw were Chinese. Same with the Federal Mogul that just played up. Link to comment Share on other sites More sharing options...
gstallons Posted April 22, 2019 Report Share Posted April 22, 2019 You should be able to have someone post a bearing part # . The base # should be the same with all companies . Anyone can cross part #s . Link to comment Share on other sites More sharing options...
docc Posted April 22, 2019 Author Report Share Posted April 22, 2019 On 4/21/2019 at 7:35 PM, gstallons said: You should be able to have someone post a bearing part # . The base # should be the same with all companies . Anyone can cross part #s . Yeah, that's how I ended up with these "Federal Mogul" branded "National" and made in China. Maybe 20,000 miles is "not too bad" (bad, but not too bad) for the brake side rear bearing, but 40k would be better! Link to comment Share on other sites More sharing options...
gstallons Posted April 22, 2019 Report Share Posted April 22, 2019 A lot of parts get reboxed when a Wholesaler changes suppliers . It happens more than you want to know . 1 Link to comment Share on other sites More sharing options...
andy york Posted April 22, 2019 Report Share Posted April 22, 2019 while your ordering all this stuff....why don't you get me a couple of u-joints ? i"ve only changed the wheel bearings once ... we have had this discussion before andy 1 1 Link to comment Share on other sites More sharing options...
Lucky Phil Posted April 22, 2019 Report Share Posted April 22, 2019 When my drive side rear wheel bearing failed I found the bearing spacer was too short so I shimmed it to stop it loading the bearing. I did however notice that the bearings felt a little tight when installed and I postulated about fitting bearings with more radial clearance. ciao 1 Link to comment Share on other sites More sharing options...
gstallons Posted April 22, 2019 Report Share Posted April 22, 2019 Where is the thread that shows all the parts interchange so we can discuss part #s ? Link to comment Share on other sites More sharing options...
docc Posted April 25, 2019 Author Report Share Posted April 25, 2019 On 4/22/2019 at 3:53 AM, gstallons said: Where is the thread that shows all the parts interchange so we can discuss part #s ? In "How to . . ." Encyclopedia of Compatible Parts 1 Link to comment Share on other sites More sharing options...
