docc Posted February 10, 2022 Report Share Posted February 10, 2022 And from the right: 2 Link to comment Share on other sites More sharing options...
docc Posted February 11, 2022 Report Share Posted February 11, 2022 It is certainly hard enough to get tools on that I went with "NyLoc" nuts on the upper fasteners. 1 Link to comment Share on other sites More sharing options...
laurent Posted February 11, 2022 Author Report Share Posted February 11, 2022 1 hour ago, docc said: So here are a few images that may help. It is very hard to get images of it in situ. LowRyter's installation from the right looking forward: MySport looking down from the left side (tank, airbox, starter, all removed), barely visible beyond the injector: From the left through the "throttle rod tunnel": The mounting tab, on the early RedFrame only, seen midway on this frame turned bottom side up: One more from the left (tank and airbox removed) : Crap, my frame does not have any upper attachment means/nothing the plate can bolt onto...it seems the bracket will be no good for my frame. 1 Link to comment Share on other sites More sharing options...
footgoose Posted February 11, 2022 Report Share Posted February 11, 2022 7 minutes ago, laurent said: Crap, my frame does not have any upper attachment means/nothing the plate can bolt onto...it seems the bracket will be no good for my frame. WTH? Link to comment Share on other sites More sharing options...
docc Posted February 11, 2022 Report Share Posted February 11, 2022 Yes, I would think you could see the edge of the frame tab from that angle. What is the month-year of the build date on your left-side headstock tag, @laurent? Link to comment Share on other sites More sharing options...
laurent Posted February 11, 2022 Author Report Share Posted February 11, 2022 52 minutes ago, docc said: Yes, I would think you could see the edge of the frame tab from that angle. What is the month-year of the build date on your left-side headstock tag, @laurent? It says 9-2000 1 Link to comment Share on other sites More sharing options...
docc Posted February 11, 2022 Report Share Posted February 11, 2022 My 3/2000 Sport has the tab. Apparently, it was eliminated for the 2001 >black< ShortFrame "Rosso Mandello." Your Greenie Sport is a 2001, @laurent? If you you feel up along the bottom of the Spine? Is the tab there? Link to comment Share on other sites More sharing options...
laurent Posted February 11, 2022 Author Report Share Posted February 11, 2022 9 minutes ago, docc said: My 3/2000 Sport has the tab. Apparently, it was eliminated for the 2001 >black< ShortFrame "Rosso Mandello." Your Greenie Sport is a 2001, @laurent? If you you feel up along the bottom of the Spine? Is the tab there? I am feeling along the bottom of her spine....remember she's naked..sorry couldn't help it. No definitely no tabs along the bottom of the spine on the id plate it says 9-2000 1 Link to comment Share on other sites More sharing options...
docc Posted February 11, 2022 Report Share Posted February 11, 2022 Is your Sport titled as a 2001, then? If I recall correctly, this is the first RedFrame we have seen without the Frame Plate mounting tab. Also, IIRC, our member @Tinus89 added a frame tab to his 2001 Rosso Mandello to install the mid-frame support plate . . . Link to comment Share on other sites More sharing options...
laurent Posted February 11, 2022 Author Report Share Posted February 11, 2022 30 minutes ago, docc said: Is your Sport titled as a 2001, then? If I recall correctly, this is the first RedFrame we have seen without the Frame Plate mounting tab. Also, IIRC, our member @Tinus89 added a frame tab to his 2001 Rosso Mandello to install the mid-frame support plate . . . Yes it is titled as a 2001 1 Link to comment Share on other sites More sharing options...
deadpen69 Posted February 11, 2022 Report Share Posted February 11, 2022 8 hours ago, docc said: Is your Sport titled as a 2001, then? If I recall correctly, this is the first RedFrame we have seen without the Frame Plate mounting tab. Also, IIRC, our member @Tinus89 added a frame tab to his 2001 Rosso Mandello to install the mid-frame support plate . . . My tag is marked 6-2000 and my frame is equipped with the tab. I guess we've already figured out the early 2000's was not a good time for Moto Guzzi! What a bummer. @laurent I would be happy to try and pull some good measurements for you as I have an unmolested tab with nothing mounted to it presently. Let me know. Link to comment Share on other sites More sharing options...
Kane Posted February 11, 2022 Report Share Posted February 11, 2022 Very weird. I thought the tabs were carried over from the Centauros and we’re there until the later V11 long frame. Every factory parts diagram I have seen for the red frame era bikes shows the frame with the tab and the bracket. An anomaly. Link to comment Share on other sites More sharing options...
Tomchri Posted February 11, 2022 Report Share Posted February 11, 2022 My 01 Greenie tittled 01 with # have no sign of a bracket, or the painter did a great job removing any signs of a bracket . IPA time here Cheers Tom. Sent fra min SM-A525F via Tapatalk 1 Link to comment Share on other sites More sharing options...
laurent Posted February 11, 2022 Author Report Share Posted February 11, 2022 Has anyone tried this new gearbox housing from germany??? https://hmb-guzzi.de/Gearbox-Housing-V11-black Link to comment Share on other sites More sharing options...
paulnaz Posted February 11, 2022 Report Share Posted February 11, 2022 Mines dated 5/2000 and I have a TAB just like Jane Paul B 2 Link to comment Share on other sites More sharing options...
