fotoguzzi Posted January 14 Report Share Posted January 14 I might like to buy this Sport but one thing puzzles me. my Lemans had a compression and rebound fork tube, note the R and C on the tops. the Sport has two R letters, what’s up, it should have one rebound and one compression right? Link to comment Share on other sites More sharing options...
fotoguzzi Posted January 14 Author Report Share Posted January 14 2 Link to comment Share on other sites More sharing options...
audiomick Posted January 14 Report Share Posted January 14 32 minutes ago, fotoguzzi said: it should have one rebound and one compression right? Not necessarily. My Le Mans has got adjustable rebound damping in both forks, and no adjustment for compression damping. I gather the earlier models had "R" and "C", but my model only ever had 2 x "R". 1 Link to comment Share on other sites More sharing options...
fotoguzzi Posted January 14 Author Report Share Posted January 14 The starter cover is included but what’s with the mounting bracket, it looks like it’s held on with hose clamps. 1 Link to comment Share on other sites More sharing options...
docc Posted January 14 Report Share Posted January 14 Yep, and have a look at how that crankcase oil drain hose can push out on (crack/break) the starter cover. All of this has has to be finely groomed, much like a cello is tuned and intoned . . . 1 Link to comment Share on other sites More sharing options...
ScuRoo Posted January 14 Report Share Posted January 14 Good luck with your purchase fotoguzzi - I can see there’s a certain charm going on with that bad boy! Link to comment Share on other sites More sharing options...
fotoguzzi Posted January 14 Author Report Share Posted January 14 With all the flywheel discussion I must ask, what FW is in the 2003? Trouble free Twin plate right? Link to comment Share on other sites More sharing options...
guzziart Posted January 14 Report Share Posted January 14 17 minutes ago, fotoguzzi said: With all the flywheel discussion I must ask, what FW is in the 2003? Trouble free Twin plate right? Yeah, I have the same question! Also, the forks on my '03 Lemans are 2xR and starter cover bracket is held on with hose clamps. Art 1 Link to comment Share on other sites More sharing options...
docc Posted January 14 Report Share Posted January 14 8 hours ago, fotoguzzi said: With all the flywheel discussion I must ask, what FW is in the 2003? Trouble free Twin plate right? 8 hours ago, guzziart said: Yeah, I have the same question! Also, the forks on my '03 Lemans are 2xR and starter cover bracket is held on with hose clamps. Art Correct, the steel flywheel of the twin plate clutch is a non-issue on all V11 models 1999-2005. It is the aluminum flywheel of the single plate clutches on the 2001 Rosso Mandello, and 2002 Scura and Tenni. The question remains unanswered if every one and all of these flywheels are suspect, or only a batch/production run of them. For instance, has a 2001 Rosso Mandello has ever suffered this failure? Or even a Tenni that we know of? 3 Link to comment Share on other sites More sharing options...
