MotoTim Posted April 30, 2023 Share Posted April 30, 2023 Hi All Well good progress to date on the Sport. Got the rear end up and wheel off for new rubber. Will do the same for the front when I get the MG "ring nut" socket delivered later this week. Took the opportunity to grease the driveshaft and lube the splines. Now for the airbox, fuel filter, valves etc.. I downloaded the Sport manual from Greg's site and between that and a search of various forums I can't find the instructions for removing the fairing.. anyone know where I can find this info? Thx Tim 1 Link to comment Share on other sites More sharing options...
docc Posted April 30, 2023 Share Posted April 30, 2023 54 minutes ago, MotoTim said: Hi All Well good progress to date on the Sport. Got the rear end up and wheel off for new rubber. Will do the same for the front when I get the MG "ring nut" socket delivered later this week. Took the opportunity to grease the driveshaft and lube the splines. Now for the airbox, fuel filter, valves etc.. I downloaded the Sport manual from Greg's site and between that and a search of various forums I can't find the instructions for removing the fairing.. anyone know where I can find this info? Thx Tim @Pressureangle question . . . Link to comment Share on other sites More sharing options...
Pressureangle Posted April 30, 2023 Share Posted April 30, 2023 28 minutes ago, docc said: @Pressureangle question . . . The fairing, yeah... too easy. 2 screws in the front sides, 2 in the tank ends, and the mirrors. The tricky part is getting it past the forks; turn the forks fully to one side or the other, and stretch anxiously. It's a bit easier if you have the tank off but not much. Putting it back on has the additional PITA of coupling the intake hoses. Overall it's very simple if a little aggro. FWIW next time my front's off I'll take the advice of others to replace the axle pin nut with a common hex nut. 2 Link to comment Share on other sites More sharing options...
