Flooky Posted May 19, 2023 Share Posted May 19, 2023 Hi folks, I started the bike today and the oil light was on, through the revs, not flickering, on solid. Searched this great site... Took sump off, filter tight. No recent oil changes ( so not 2 filter gaskets ) Nothing horrid in the sump and strainer clear Oil level fine. Refitted sump. Tried to remove oul pressure switch but seems tricky without removing tank. ( sundays job ) Any pointers would be great, is it likely to be the switch ( when i pull the wire off the light goes out ) Or something else ? Cheers Link to comment Share on other sites More sharing options...
Chuck Posted May 19, 2023 Share Posted May 19, 2023 Yes, it's the switch. 4 Link to comment Share on other sites More sharing options...
Weegie Posted May 21, 2023 Share Posted May 21, 2023 Almost certainly what Chuck said The switches are well known failure points. If it was my bike, I'd order a new switch, but I wouldn't run the bike until I confirmed it, or put on a temp pressure gauge to confirm the engine pressure is good. Almost certainly the switch but even with the odds in my favour I wouldn't take a chance (but that's just me). Another quick and dirty (literally) check would be to remove one of the head feeds or the switch and whirl it over on the starter, you'll soon know if engine pressure is good.............hint wear coveralls and old boots Pulling the wires off the switch confirms that the wiring and connectors are fine, it doesn't tell you anything about the pressure Good luck with it 4 Link to comment Share on other sites More sharing options...
Flooky Posted May 21, 2023 Author Share Posted May 21, 2023 Thanks folks, I will order a new switch tommorrow. Got the old one off and i am now replacing the tank to pump fuel hose. This forum is great. I would be lost without it 7 Link to comment Share on other sites More sharing options...
Flooky Posted May 23, 2023 Author Share Posted May 23, 2023 Thanks.. Switch fitted, new oil, new fuel tank to pump fuel line seems ok too. All good now..lights out as it should be. 7 Link to comment Share on other sites More sharing options...
