dbarb3 Posted August 16 Share Posted August 16 Did a search and got a thousand posts Trying to troubleshoot speedometer, MPH nor either odometer is working, tach works fine.. I unscrwed cable from ispeedometer end and cranked engine, it soes not turn, does that indicate cable issue. Just getting started on it and trying to save some steps if psssible. Link to comment Share on other sites More sharing options...
GuzziMoto Posted August 16 Share Posted August 16 A broken cable is the most common issue with the cable driven stock speedometer. But to check the cable you need to do more than remove the cable from the speedometer and crank the engine over. An easy test is to remove the cable from both the transmission and from the speedometer. Then you can check to make sure the cable is not broken. Also make sure that one end isn't broken off. It is easy for the end of the cable to break off and not be noticed. 1 Link to comment Share on other sites More sharing options...
dbarb3 Posted August 16 Author Share Posted August 16 Well that makes sense thank you Link to comment Share on other sites More sharing options...
GuzziMoto Posted August 16 Share Posted August 16 If you remove the cable, be careful with it. The inner part of the cable that spins is not fixed inside the cable and can slide out. Not a problem if it does slide out, just be careful as you don't want it to fall out and get damaged when you weren't expecting it. Not a problem if you slide it out in a controlled way to verify the cable is not broken inside. Link to comment Share on other sites More sharing options...
docc Posted August 16 Share Posted August 16 3 hours ago, dbarb3 said: Did a search and got a thousand posts Trying to troubleshoot speedometer, MPH nor either odometer is working, tach works fine.. I unscrwed cable from ispeedometer end and cranked engine, it soes not turn, does that indicate cable issue. Just getting started on it and trying to save some steps if psssible. In all of my white face Veglia speedometer tribulations, I never had a broken cable. Lots of issues with the lower angle drive at the gearbox, though. Kneel down on the right side of the bike and inspect the angle drive, especially for the presence, or absence, of the metal disc that holds the drive gear in place. I can post images of that later if helpful...... [edit: Here is a link to a post: Link to comment Share on other sites More sharing options...
LaGrasta Posted August 16 Share Posted August 16 I recently chased similar problems. Upon reassemble with new parts, it still did not work …then it did. It seems they lock into each other rather obvious, but I repeatedly didn't have them fully engaged, thus not working. I ended up replacing both 60° gear units and the cable during my troubleshooting, it was actually the speedo-side gear that was broken. Keep at it, you'll figure it out. 1 Link to comment Share on other sites More sharing options...
activpop Posted August 17 Share Posted August 17 Any way to lube that stuff when its out? I have always used DriSlide for cables, still have a can from the 80's with a bit in it. To my surprise, they still sell it today. Good product. Link to comment Share on other sites More sharing options...
cash1000 Posted August 17 Share Posted August 17 There is a speedo cable now available the does away with the 60 gear units. I've run mine for a few 1000 k's now with no problem. I've got a post in here somewhere about it. Link to comment Share on other sites More sharing options...
LaGrasta Posted August 17 Share Posted August 17 16 hours ago, activpop said: Any way to lube that stuff when its out? I have always used DriSlide for cables, still have a can from the 80's with a bit in it. To my surprise, they still sell it today. Good product. You sure can. I placed grease in each gear drive, as well as a few drops of lube into the cable. 1 Link to comment Share on other sites More sharing options...
dbarb3 Posted August 19 Author Share Posted August 19 Well seems nothing is simple with me or MG I have new cable in and needle is all over the place. Guess I will visit the article referenced above. Link to comment Share on other sites More sharing options...
