So the spring(gu04238300) failed.
I managed to get home!
I have read all the posts and understand the reason why it fails.
I’ve got the new spring. Actually bought 2, so can go ahead and replace it.
Forgive my lack of knowledge, when I removed the gearbox cover it was metal to metal. It came off really easy and has never leaked! No gasket and no gasket sealer.
I read that LOCTITE 518 sealer has been used and therefore creates a seal. Also filing down the shaft to 15mm s
The reason Guzzitech’s boss rants about The Guzzidiag suite of tools is because using them cuts into his profiteering from selling unnecessary, obsolete shit that he doesn’t even understand and often doesn’t work.
Using Guzzidiag and the ‘Reader’ and ‘Writer’ programs CANNOT brick or otherwise damage your ECU. Using a correctly constructed aftermarket map allows you to achieve far more, far better, than using a shitty add-on like a Power Commander or the like.
Quite simply it is my bel
